Hi all,
Hoping a couple of eyes on this will help me solve it. I haven’t made much use of the preview token exchange feature, and I am trying to set up an example for Internal token to internal token exchange as described in the documentation.
Here’s the Keycloak setup:
- I made two Clients,
test
andtarget
, both public clients with the same setup
- In the
target
Client, I enabled fine grained permissions
- In the
realm-management
Client, Authorization->Policies tab, I made a new Client policy calledtarget-client-exchange
with the configuration that included thetest
client
- Back in the
target
Client, Permissions tab, I configured thetoken-exchange
permission with the policy I created in #3
And here is how I try to use it:
var keycloak = Keycloak(); //this reads the client configuration for the `test` client
keycloak.init({
onLoad: 'login-required'
}).then(function(authenticated) {
tokenExchange();
}).catch(function() {
console.log('failed to initialize');
function tokenExchange() {
const url = keycloak.endpoints.token();
var details = {
'client_id': keycloak.clientId,
'grant_type': 'urn:ietf:params:oauth:grant-type:token-exchange',
'subject_issuer': keycloak.tokenParsed.iss,
'subject_token': keycloak.token,
'subject_token_type': 'urn:ietf:params:oauth:token-type:access_token',
'requested_token_type': 'urn:ietf:params:oauth:token-type:refresh_token',
'audience': 'target'
var formBody = [];
for (var property in details) {
var encodedKey = encodeURIComponent(property);
var encodedValue = encodeURIComponent(details[property]);
formBody.push(encodedKey + "=" + encodedValue);
formBody = formBody.join("&");
fetch(url, {
method: 'POST',
mode: 'cors',
cache: 'no-cache',
credentials: 'same-origin',
headers: {
'Content-Type': 'application/x-www-form-urlencoded',
redirect: 'follow',
referrerPolicy: 'no-referrer',
body: formBody
.then((response) => console.log(response))
.then((data) => console.log(data));
After logging in, the tokenExchange()
function runs, returns a 200, but there is nothing in the response. No errors in the Keycloak logs either. However, there is an event that indicates a successful token exchange happened
Any ideas on how I can get a token? What am I doing wrong?
