I am using keycloak with google sso enabled.
If a new user tries to login using sso, keycloak is creating a new user and then will complete the login process. Since user is not added to any groups, user will not be able to access anything in th application.
Is there a way we can disable the automatic user creation with sso?
You mean like when the user logs in the system, keycloak should not create an account for the newly logged in user? But how keycloak will retrieve user data later on if it doesn’t create an account for the user?
@thomasavio
I am creating user through another flow with custom username and another custom fields which will be taken from my backend table.
The issue is if I enable sso, user without an account is able to login using sso (He won’t be able to access anything). keyclaok is creating a new user with username as the gmail which is received from sso.
@lamoboos223
@thomasavio what do you mean by enabling sso? Can you give screenshots?
@lamoboos223
With google sso disabled
enabled
if a new user click on sign in with google keycloak is creating a new account.
Ok i see it now, ok instead of using the builtin google social login, why don’t create your own google social login so you apply the custom rules on the username?
@thomasavio
User creation I will handle via admin api, since I will get the custom fields I need to add only if I add the user to application DB first.
The only thing I need here is if a new user (who don’t an account) tries to login via sso, keycloak should throw an error saying user does not exist instead of creating a user.
@lamoboos223
So you want anyone who login with google social login to have certain group/role once their account is created in keycloak. Have you thought of mappers in the configuration?
Navigate to the Identity Providers section in Keycloak and select your Google identity provider.
• Go to the “Mappers” tab.
• Create a new Mapper of type “Hardcoded Role” or “Hardcoded Group”.
• Set the role or group you want to assign to the user upon login.
For this requirement, the Detect existing broker user
authenticator step might be your friend:
Detect if there is an existing Keycloak account with same email like identity provider. If no, throw an error.
Create a custom “first broker login” flow where you integrate the above mentioned step properly as desired.
@dasniko
When user tries to login via sso
- check if a user with same email exist or throw error
- if a user with that email exist and identity provider details are not saved, then save that and login the user
- if the identity providers details are already saved then login the user
can you please provide a sample to implement this flow.
below is the default flow
