So here is what i did
Using my local keycloak server (thru docker), i created a realm, users, role and client
I set up credentials and got secret key and stuff and thats it, i havent set anything, no mappers, client scope, etc.
I did this as our other applications that is using other languages such as PHP or nodejs have similar settings.
then I created a fresh ASP.NET Core MVC application and setup the openid options like so
services.AddAuthentication(options =>
//Sets cookie authentication scheme
options.DefaultAuthenticateScheme = CookieAuthenticationDefaults.AuthenticationScheme;
options.DefaultSignInScheme = CookieAuthenticationDefaults.AuthenticationScheme;
options.DefaultChallengeScheme = OpenIdConnectDefaults.AuthenticationScheme;
.AddCookie(cookie =>
//Sets the cookie name and maxage, so the cookie is invalidated.
cookie.Cookie.Name = "keycloak.cookie";
cookie.Cookie.MaxAge = TimeSpan.FromMinutes(60);
cookie.Cookie.SecurePolicy = CookieSecurePolicy.SameAsRequest;
cookie.SlidingExpiration = true;
.AddOpenIdConnect(options =>
//Use default signin scheme
options.SignInScheme = CookieAuthenticationDefaults.AuthenticationScheme;
//Keycloak server
options.Authority = Configuration.GetSection("Keycloak")["ServerRealm"];
//Keycloak client ID
options.ClientId = Configuration.GetSection("Keycloak")["ClientId"];
//Keycloak client secret
options.ClientSecret = Configuration.GetSection("Keycloak")["ClientSecret"];
//Keycloak .wellknown config origin to fetch config
// options.MetadataAddress = Configuration.GetSection("Keycloak")["Metadata"];
//Require keycloak to use SSL
options.RequireHttpsMetadata = false;
options.GetClaimsFromUserInfoEndpoint = true;
options.Scope.Add("openid");
options.Scope.Add("profile");
options.Scope.Add("email");
//Save the token
options.SaveTokens = true;
//Token response type, will sometimes need to be changed to IdToken, depending on config.
options.ResponseType = OpenIdConnectResponseType.Code;
//SameSite is needed for Chrome/Firefox, as they will give http error 500 back, if not set to unspecified.
options.NonceCookie.SameSite = SameSiteMode.None;
options.CorrelationCookie.SameSite = SameSiteMode.None;
options.TokenValidationParameters = new TokenValidationParameters
NameClaimType = "name",
RoleClaimType = "https://schemas.scopic.com/roles"
Configuration.Bind("<Json Config Filter>", options);
options.Events.OnRedirectToIdentityProvider = async context =>
context.ProtocolMessage.RedirectUri = "http://localhost:13636/home";
await Task.FromResult(0);
app.UseHttpsRedirection();
app.UseStaticFiles();
app.UseRouting();
app.UseAuthentication();
app.UseAuthorization();
and in my HomeController like so
public class HomeController : Controller
private readonly ILogger<HomeController> _logger;
public HomeController(ILogger<HomeController> logger)
_logger = logger;
public IActionResult Index()
bool value = User.Identity.IsAuthenticated;
return View();
[Authorize]
public IActionResult Privacy()
return View();
when i access localhost:13636/Privacy to test, the Keycloak login page is triggered which is correct,
but after succesful login and redirects to /home, User.Identity.IsAuthenticated is false and it seems like the application doesnt know that authentication is succesful.
What needs to be done after this?
or am I missing some configuration/settings/options?
