I am using keycloak to implement OAuth2 code authorization flow in a kubernetes cluster governed by an API gatware Ambassador, I am using Istio Service mesh to add all the tracability, mTLS features to my cluster. One of which is Jaeger which requires all the services to forward x-request-id
header in order to link the spans into a specific trace.
When request is sent, Istio’s proxy attached to ambassador will generate the x-request-id and forward the request keycloak for authorization, when the results are sent back to the ambassador, the header is dropped (step 4 in the figure) and therefore, the istio proxy of keycloak will be generating a new x-header-id
. The following image shows the problem:
Here is a photo of the trace where I lost the x-request-id:
Is there a way I can force Keycloak to forward the x-request-id
header if passed to it?
Update
here is the environment variables (ConfigMap) associated with Keycloak:
kind: ConfigMap
apiVersion: v1
metadata:
data:
KEYCLOAK_ADMIN: "admin"
KC_PROXY: "edge"
KC_DB: "postgres"
KC_DB_USERNAME: "test"
KC_DB_DATABASE: "keycloak"
PROXY_ADDRESS_FORWARDING: "true"
