We currently run keycloak 16 Wildfly in a docker across 4 tasks on an ECS cluster. This cluster and cache is configured in the standalone-ha.xml file. Within this, we use the following blocks to set the TCP and socket binding. We then have terraform to create the cluster on ECS. This works.
<stack name="tcp">
<transport type="TCP" socket-binding="jgroups-tcp">
<property name="external_addr">${env.INSTANCE_IP}</property>
</transport>
<protocol type="org.jgroups.protocols.JDBC_PING">
<property name="datasource_jndi_name">java:jboss/datasources/KeycloakDS</property>
<property name="initialize_sql">
CREATE TABLE IF NOT EXISTS JGROUPSPING (own_addr varchar(200) NOT NULL,bind_addr varchar(200) NOT NULL,created timestamp NOT NULL,cluster_name varchar(200) NOT NULL,ping_data BYTEA,constraint PK_JGROUPSPING PRIMARY KEY (own_addr, cluster_name)); DELETE FROM JGROUPSPING WHERE created < (current_timestamp - interval '2' day);
</property>
<property name="insert_single_sql">
INSERT INTO JGROUPSPING (own_addr, bind_addr, created, cluster_name, ping_data) values (?,'${jgroups.tcp.address:127.0.0.1}',NOW(), ?, ?)
</property>
</property>
<property name="delete_single_sql">DELETE FROM JGROUPSPING WHERE own_addr=? AND cluster_name=?</property>
<property name="select_all_pingdata_sql">SELECT ping_data FROM JGROUPSPING WHERE cluster_name=?</property>
</protocol>
</stack>
<socket-binding-group name="standard-sockets" default-interface="public" port-offset="${jboss.socket.binding.port-offset:0}">
<socket-binding name="ajp" port="${jboss.ajp.port:8009}"/>
<socket-binding name="http" port="${jboss.http.port:8080}">
<client-mapping destination-address="${jboss.host.name}"/>
</socket-binding>
<socket-binding name="https" port="${jboss.https.port:8443}"/>
<socket-binding name="jgroups-mping" interface="private" multicast-address="${jboss.default.multicast.address:230.0.0.4}" multicast-port="45700"/>
<socket-binding name="jgroups-tcp" interface="public" port="7600"/>
<socket-binding name="jgroups-tcp-fd" interface="private" port="57600"/>
<socket-binding name="jgroups-udp" interface="private" port="55200" multicast-address="${jboss.default.multicast.address:230.0.0.4}" multicast-port="45688"/>
<socket-binding name="jgroups-udp-fd" interface="private" port="54200"/>
<socket-binding name="management-http" interface="management" port="${jboss.management.http.port:9990}"/>
<socket-binding name="management-https" interface="management" port="${jboss.management.https.port:9993}"/>
<socket-binding name="modcluster" multicast-address="${jboss.modcluster.multicast.address:224.0.1.105}" multicast-port="23364"/>
<socket-binding name="txn-recovery-environment" port="4712"/>
<socket-binding name="txn-status-manager" port="4713"/>
<outbound-socket-binding name="mail-smtp">
<remote-destination host="${jboss.mail.server.host:localhost}" port="${jboss.mail.server.port:25}"/>
</outbound-socket-binding>
</socket-binding-group>
The problem….
We have recently started moving to 17.0.1 Quarkus and part of that includes setting the cache config in the keycloak.conf file as follows.
cache=ispn
cache-stack=tcp
cache-config-file=clusterConfig.xml
And then the clusterConfig.xml
<jgroups>
<stack name="jdbc-ping-tcp" extends="tcp">
<TCP external_addr="${env.INSTANCE_IP}"
bind_port="7800"
<JDBC_PING connection_driver="org.postgresql.Driver"
connection_username="${env.POSTGRES_USER}"
connection_password="${env.POSTGRES_PASSWORD}"
connection_url="jdbc:postgresql://${env.POSTGRES_PORT_5432_TCP_ADDR}:5432/${env.POSTGRES_DATABASE}"
initialize_sql="CREATE TABLE IF NOT EXISTS JGROUPSPING (own_addr varchar(200) NOT NULL,bind_addr varchar(200) NOT NULL,created timestamp NOT NULL,cluster_name varchar(200) NOT NULL,ping_data BYTEA,constraint PK_JGROUPSPING PRIMARY KEY (own_addr, cluster_name)); DELETE FROM JGROUPSPING WHERE created < (current_timestamp - interval '2' day);"
insert_single_sql="INSERT INTO JGROUPSPING (own_addr, bind_addr, created, cluster_name, ping_data) values (?,'${jgroups.tcp.address:127.0.0.1}',NOW(), ?, ?)"
delete_single_sql="DELETE FROM JGROUPSPING WHERE own_addr=? AND cluster_name=?"
select_all_pingdata_sql="SELECT ping_data FROM JGROUPSPING WHERE cluster_name=?"
info_writer_sleep_time="500"
remove_all_data_on_view_change="true"
stack.combine="REPLACE"
stack.position="MPING" />
</stack>
</jgroups>
<transport lock-timeout="60000" stack="jdbc-ping-tcp"/>
<local-cache name="realms">
<encoding>
</encoding>
<memory max-count="10000"/>
</local-cache>
<local-cache name="users">
<encoding>
</encoding>
</local-cache>
<encoding>
</encoding>
</local-cache>
<local-cache name="keys">
<encoding>
</encoding>
<memory max-count="1000"/>
</local-cache>
<expiration lifespan="900000000000000000"/>
</replicated-cache>
<distributed-cache name="sessions" owners="4">
<expiration interval="18000000" lifespan="900000000000000000" max-idle="-1"/>
</distributed-cache>
<distributed-cache name="authenticationSessions" owners="4">
<distributed-cache name="offlineSessions" owners="4">
<distributed-cache name="clientSessions" owners="4">
<distributed-cache name="offlineClientSessions" owners="4">
<distributed-cache name="loginFailures" owners="4">
<distributed-cache name="actionTokens" owners="4">
<encoding>
</encoding>
</cache-container>
The above configuration works to create a “cluster” of 1…
Keycloak 17.0.1 seems to use infinispan 13.0.6.Final at some built in level and this XML schema refers to the JGROUPS one which allows the block to work. It is only the infinispan:config XML schema though so adding any information into the clusterConfig.xml file, so that I can add the socket-binding and interfaces, is impossible.
The Question.
How do I configure Keycloak 17 Quarkus to work with an ECS cluster. WHERE in WHAT config can I set the socket-binding instructions?
Please please please. Any ideas considered. Official documentation around this is minimal at best.
Thanks
Tom.
