I’m sure I have something configured incorrectly there, but I get the following error:
2022-11-01 17:16:28,764 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: Failed to start server in (production) mode
2022-11-01 17:16:28,765 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: Failed to start caches
2022-11-01 17:16:28,765 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: org.infinispan.manager.EmbeddedCacheManagerStartupException: org.infinispan.commons.CacheConfigurationException: ISPN000085: Error while trying to create a channel using the specified configuration file: default-configs/default-jgroups-ec2.xml
2022-11-01 17:16:28,765 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: org.infinispan.commons.CacheConfigurationException: ISPN000085: Error while trying to create a channel using the specified configuration file: default-configs/default-jgroups-ec2.xml
2022-11-01 17:16:28,765 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: ISPN000085: Error while trying to create a channel using the specified configuration file: default-configs/default-jgroups-ec2.xml
2022-11-01 17:16:28,765 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: JGRP000002: unable to load protocol org.jgroups.aws.s3.NATIVE_S3_PING (either with relative - org.jgroups.aws.s3.NATIVE_S3_PING - or absolute - org.jgroups.protocols.org.jgroups.aws.s3.NATIVE_S3_PING - class name)
2022-11-01 17:16:28,765 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) For more details run the same command passing the '--verbose' option. Also you can use '--help' to see the details about the usage of the particular command.
I’m struggling to get this working and have spent all day today trying to get to the bottom of it, has anyone got working configuration they are willing to share or point me in the right direction?
I don’t know how to configure the EC2 stack, BUT…
It has been said quite multiple times here in the forum in various threads about cluster configuration, that, if you configure cache-stackANDcache-config-file, the former will take higher precedence over the latter and your custom file will be ignored. So, if you want to use one of the built-in stacks, use cache-stack, if you want to use a custom stack with a xml file, specify it with cache-config-file.
How does that work with S3 where you need to specify the bucket?
Or do you specify it with ENV variables?
Would be good if there was a keycloak example xml file for each of the infinispan implementations, as there is obviously some wrapping around the default infinispan xml - at least from comparing JDBC_PING, which didn’t work for me in AWS as has been reported as well.
Based on this and this you need to select the ec2 stack and provide AWS credentials for the underlying library used by it.
I suppose you can just put those lines in your keycloak.conf (besides removing the cache-stack as stated in the previous answers, you can use on or the other):
cache=ispn
cache-stack=ec2
Run keycloak with those environment variables set (replace with your own values):
I am away from the office today, so unable to test it… but does anyone know if you can skip providing the AWS credentials and use an IAM role in it’s place, I will be unable to create credentials due to security requirements but can use an IAM role attached to the EC2 (and the equivelent bucket policy applied for said role).
If the IAM role is attached to the ec2 instance itself, I suppose you can just set bucketname and credentials will be handled for you by the java SDK under the hood.
IAM profile role should be applied to EC2 instance (for AWS creds) and S3 bucket created
Build Keycloak with option --cache-stack=ec2 (no --cache-config-file option!)
bin/kc.[sh|bat] build --cache-stack=ec2
By me it’s working) GL& HF!
Logs:
2023-02-21 09:47:28,062 INFO [org.infinispan.server.core.transport.EPollAvailable] (keycloak-cache-init) ISPN005028: Native Epoll transport not available, using NIO instead: java.lang.ExceptionInInitializerError
2023-02-21 09:47:28,453 WARN [org.infinispan.CONFIG] (keycloak-cache-init) ISPN000569: Unable to persist Infinispan internal caches as no global state enabled
2023-02-21 09:47:28,472 WARN [org.infinispan.PERSISTENCE] (keycloak-cache-init) ISPN000554: jboss-marshalling is deprecated and planned for removal
2023-02-21 09:47:28,506 INFO [org.infinispan.CONTAINER] (keycloak-cache-init) ISPN000556: Starting user marshaller 'org.infinispan.jboss.marshalling.core.JBossUserMarshaller'
2023-02-21 09:47:28,987 INFO [org.keycloak.broker.provider.AbstractIdentityProviderMapper] (main) Registering class org.keycloak.broker.provider.mappersync.ConfigSyncEventListener
2023-02-21 09:47:29,086 INFO [org.infinispan.CONTAINER] (keycloak-cache-init) ISPN000128: Infinispan version: Infinispan 'Triskaidekaphobia' 13.0.10.Final
2023-02-21 09:47:29,270 INFO [org.infinispan.CLUSTER] (keycloak-cache-init) ISPN000078: Starting JGroups channel `ISPN`
2023-02-21 09:47:29,290 WARN [org.jgroups.stack.Configurator] (keycloak-cache-init) NATIVE_S3_PING has been deprecated; please upgrade to a newer version of the protocol
2023-02-21 09:47:30,181 INFO [org.jgroups.aws.s3.NATIVE_S3_PING] (keycloak-cache-init) using Amazon S3 ping in region us-east-1 with bucket 'my-jgroups-s3-bucket-test' and prefix ''
2023-02-21 09:47:30,937 INFO [org.jgroups.aws.s3.NATIVE_S3_PING] (keycloak-cache-init) found bucket my-jgroups-s3-bucket-test
2023-02-21 09:48:04,101 INFO [org.infinispan.CLUSTER] (keycloak-cache-init) ISPN000094: Received new cluster view for channel ISPN: [ip-10-68-49-170-40943|3] (2) [ip-10-68-49-170-40943, ip-10-68-49-190-31671]
2023-02-21 09:48:04,111 INFO [org.infinispan.CLUSTER] (keycloak-cache-init) ISPN000079: Channel `ISPN` local address is `ip-10-68-49-190-31671`, physical addresses are `[10.68.49.190:7800]`
2023-02-21 09:48:07,087 INFO [io.quarkus] (main) Keycloak 20.0.3 on JVM (powered by Quarkus 2.13.6.Final) started in 78.156s. Listening on: http://0.0.0.0:8080 and https://0.0.0.0:8443
2023-02-21 09:48:07,087 INFO [io.quarkus] (main) Profile prod activated.
