We have just updated to 21.0.2 and with our Identity Provider Login we are receiving the following error:
2023-04-21 08:35:24,975 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (executor-thread-144) Uncaught server error: org.keycloak.broker.provider.IdentityBrokerException: Could not process response from SAML identity provider.
at org.keycloak.broker.saml.SAMLEndpoint$Binding.handleLoginResponse(SAMLEndpoint.java:596)
at org.keycloak.broker.saml.SAMLEndpoint$Binding.handleSamlResponse(SAMLEndpoint.java:679)
at org.keycloak.broker.saml.SAMLEndpoint$Binding.execute(SAMLEndpoint.java:278)
at org.keycloak.broker.saml.SAMLEndpoint.postBinding(SAMLEndpoint.java:189)
at jdk.internal.reflect.GeneratedMethodAccessor666.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at io.vertx.ext.web.impl.RouteState.handleContext(RouteState.java:1284)
at io.vertx.ext.web.impl.RoutingContextImplBase.iterateNext(RoutingContextImplBase.java:173)
at io.vertx.ext.web.impl.RoutingContextWrapper.next(RoutingContextWrapper.java:200)
at io.quarkus.vertx.http.runtime.StaticResourcesRecorder$2.handle(StaticResourcesRecorder.java:84)
at io.quarkus.vertx.http.runtime.StaticResourcesRecorder$2.handle(StaticResourcesRecorder.java:71)
at io.quarkus.vertx.http.runtime.VertxHttpRecorder$6.handle(VertxHttpRecorder.java:430)
at io.quarkus.vertx.http.runtime.VertxHttpRecorder$6.handle(VertxHttpRecorder.java:408)
at org.keycloak.quarkus.runtime.integration.web.QuarkusRequestFilter.lambda$createBlockingHandler$0(QuarkusRequestFilter.java:82)
at io.quarkus.vertx.core.runtime.VertxCoreRecorder$14.runWith(VertxCoreRecorder.java:576)
at java.base/java.lang.Thread.run(Thread.java:833)
Caused by: java.lang.RuntimeException: PL00092: Null Value:Key for EncryptedData not found.
at org.keycloak.saml.common.DefaultPicketLinkLogger.nullValueError(DefaultPicketLinkLogger.java:194)
at org.keycloak.saml.processing.core.util.XMLEncryptionUtil.decryptElementInDocument(XMLEncryptionUtil.java:272)
at org.keycloak.saml.processing.core.saml.v2.util.AssertionUtil.decryptAssertion(AssertionUtil.java:612)
at org.keycloak.broker.saml.SAMLEndpoint$Binding.handleLoginResponse(SAMLEndpoint.java:449)
... 50 more
Configuration for the IDP hasn’t changed, and I have tried to troubleshoot with various options on the Identity Provider but to no luck.
