Could not process response from SAML identity provider
I’m configuring my IdP with keycloak but after successful login, My IdP sends a saml response but i’m seeing this error. I’ve tried a lot but still getting this error.
Error
17:51:11,469 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (default task-36) Uncaught server error: org.keycloak.broker.provider.IdentityBrokerException: Could not process response from SAML identity provider.
We would need to see the full IdP configuration (both an Keycloak and the remote IdP) and a SAML trace (try something like SAML-tracer) in order to help. That error isn’t specific enough to know what is going on. If you can post your configs and trace, we should be able to help.
Error We are getting is Invalid Saml Response
14:50:03,457 ERROR [org.keycloak.protocol.saml.installation.SamlSPDescriptorClientInstallation] (default task-54) Cannot generate SP metadata: java.net.URISyntaxException: Illegal chara
cter in path at index 3: NIC Key Cloak Client
at java.net.URI$Parser.fail(URI.java:2848)
at java.net.URI$Parser.checkChars(URI.java:3021)
at java.net.URI$Parser.parseHierarchical(URI.java:3105)
at java.net.URI$Parser.parse(URI.java:3063)
at java.net.URI.(URI.java:588)
at org.keycloak.protocol.saml.installation.SamlSPDescriptorClientInstallation.getSPDescriptorForClient(SamlSPDescriptorClientInstallation.java:102)
at org.keycloak.protocol.saml.installation.SamlSPDescriptorClientInstallation.generateInstallation(SamlSPDescriptorClientInstallation.java:118)
at org.keycloak.services.resources.admin.ClientResource.getInstallationProvider(ClientResource.java:205)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:249)
at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:60)
at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:55)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
at io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:74)
at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
at org.keycloak.provider.wildfly.WildFlyRequestFilter.lambda$doFilter$0(WildFlyRequestFilter.java:41)
at org.keycloak.services.filters.AbstractRequestFilter.filter(AbstractRequestFilter.java:43)
at org.keycloak.provider.wildfly.WildFlyRequestFilter.doFilter(WildFlyRequestFilter.java:39)
at io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61)
at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131)
at io.undertow.servlet.handlers.FilterHandler.handleRequest(FilterHandler.java:84)
at io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
at io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68)
at io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
at org.wildfly.elytron.web.undertow.server.ElytronRunAsHandler.lambda$handleRequest$1(ElytronRunAsHandler.java:68)
at org.wildfly.security.auth.server.FlexibleIdentityAssociation.runAsFunctionEx(FlexibleIdentityAssociation.java:103)
at org.wildfly.security.auth.server.Scoped.runAsFunctionEx(Scoped.java:161)
at org.wildfly.security.auth.server.Scoped.runAs(Scoped.java:73)
at org.wildfly.elytron.web.undertow.server.ElytronRunAsHandler.handleRequest(ElytronRunAsHandler.java:67)
at io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68)
at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:117)
at io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
at io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
at io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
at io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
at io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
at org.wildfly.elytron.web.undertow.server.servlet.CleanUpHandler.handleRequest(CleanUpHandler.java:38)
at org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
at org.wildfly.extension.undertow.deployment.GlobalRequestControllerHandler.handleRequest(GlobalRequestControllerHandler.java:68)
at io.undertow.servlet.handlers.SendErrorPageHandler.handleRequest(SendErrorPageHandler.java:52)
at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:280)
at io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:79)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:134)
at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:131)
at io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48)
at org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1544)
at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:260)
at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:79)
at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:100)
at io.undertow.server.Connectors.executeRootHandler(Connectors.java:387)
at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:852)
at org.jboss.threads.EnhancedQueueExecutor.safeRun(EnhancedQueueExecutor.java:1990)
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.doRunTask(EnhancedQueueExecutor.java:1486)
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1377)
at org.xnio.XnioWorker$WorkerThreadFactory$1$1.run(XnioWorker.java:1280)
Can we setup a google meet?
I’m geeting error while my IDP is sending final SAMLResponse. The Error i’m geeting is invalid_destination or invalid_saml_response.
Hi there, I am facing a similar issue setting up SSO with Azure AD, Keycloak 21.1.1 and WildFly 20.0.1.Final I receive the SAML response from Azure AD and everything looks correct. My suspicion is that I have something configured in my IdP on Keycloak that it is looking for in the response which is not there, could you let me know if I am on the right track or point me in the right direction? Thanks
2023-05-04 10:23:57,174 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (executor-thread-133) Uncaught server error: org.keycloak.broker.provider.IdentityBrokerException: Could not process response from SAML identity provider.
at org.keycloak.broker.saml.SAMLEndpoint$Binding.handleLoginResponse(SAMLEndpoint.java:596)
at org.keycloak.broker.saml.SAMLEndpoint$Binding.handleSamlResponse(SAMLEndpoint.java:679)
at org.keycloak.broker.saml.SAMLEndpoint$Binding.execute(SAMLEndpoint.java:278)
at org.keycloak.broker.saml.SAMLEndpoint.postBinding(SAMLEndpoint.java:189)
at java.base/java.lang.reflect.Method.invoke(Method.java:567)
at io.vertx.ext.web.impl.RouteState.handleContext(RouteState.java:1284)
at io.vertx.ext.web.impl.RoutingContextImplBase.iterateNext(RoutingContextImplBase.java:173)
at io.vertx.ext.web.impl.RoutingContextImpl.next(RoutingContextImpl.java:140)
at io.quarkus.vertx.http.runtime.StaticResourcesRecorder$2.handle(StaticResourcesRecorder.java:84)
at io.quarkus.vertx.http.runtime.StaticResourcesRecorder$2.handle(StaticResourcesRecorder.java:71)
at io.quarkus.vertx.http.runtime.VertxHttpRecorder$6.handle(VertxHttpRecorder.java:430)
at io.quarkus.vertx.http.runtime.VertxHttpRecorder$6.handle(VertxHttpRecorder.java:408)
at org.keycloak.quarkus.runtime.integration.web.QuarkusRequestFilter.lambda$createBlockingHandler$0(QuarkusRequestFilter.java:82)
at io.quarkus.vertx.core.runtime.VertxCoreRecorder$14.runWith(VertxCoreRecorder.java:576)
at java.base/java.lang.Thread.run(Thread.java:835)
Caused by: java.lang.NullPointerException
I just recently dealt with a very similar issue. I can’t be sure that we are having the same problem, but the top of my stack trace looked pretty much that same as yours (handleLoginResponse, handleSamlResponse, execute, postBinding, the line numbers were different but I’m on version 20.0.2 which could explain that difference) and the problem turned out to be that the identity provider I was working with was configured to use an idp-initiated saml workflow. I changed the idp settings to use “SP-initiated” and made sure to make the “Connection URL” (which was just the link in the idp application portal) to point directly to my application (as opposed to pointing to the idp sso url) and it worked.
I think what was happening under the hood to cause the NPE was that the link in the idp application portal would send the user to the “Single-Sign-On URL” directly without going to the keycloak realm first, the idp would then redirect the user to the Keycloak ACS URL and attempt to do the POST-binding, then keycloak would attempt to process the POST-binding request assuming that there was an existing state to compare the incoming request to as there would be if keycloak has initiated the saml workflow, since that state didn’t exist it caused an NPE.
Hope that helps!
Thanks very much for the response, while I didn’t have the same problem this certainly helped. I removed all configurations in keycloak, set up a new enterprise application in azure and started again. The problem had to do with how I had originally set up the Entity ID and reply url of keycloak in azure.
