We have a requirement where we need to integrate AWS as identity provider with Identity Access Manager tool. In the identity provider section there is no option to select for AWS. Is there any way out where we can use AWS as identity provider in keycloak
If you are referring to AWS IAM Identity Center (Successor to AWS Single Sign-On) you can connect it as a standard SAML 2.0 identity provider.
