I’m currently upgrading Keycloak from 16.1.0 to 18.0.2. So I have to change from Wildfly to Quarkus. I’m now struggling with the configuration of a second database pool for my SPIs. In the keycloak.conf you can only configure one datasource. With Wildfly I used the following configuartion:
<subsystem xmlns="urn:jboss:domain:datasources:6.0">
<datasources>
<xa-datasource jndi-name="java:jboss/datasources/keycloakDatabase" pool-name="keycloakDatabase" enabled="true" use-java-context="true" statistics-enabled="${wildfly.datasources.statistics-enabled:${wildfly.statistics-enabled:false}}">
...Configuration like username and password...
</xa-datasource>
<xa-datasource jndi-name="java:jboss/datasources/secondDatabase" pool-name="secondDatabase" enabled="true" use-java-context="true" statistics-enabled="${wildfly.datasources.statistics-enabled:${wildfly.statistics-enabled:false}}">
<driver>oracle</driver>
<xa-pool>
<min-pool-size>0</min-pool-size>
<max-pool-size>100</max-pool-size>
<prefill>true</prefill>
<allow-multiple-users>false</allow-multiple-users>
<is-same-rm-override>false</is-same-rm-override>
</xa-pool>
<validation>
<validate-on-match>false</validate-on-match>
<background-validation>false</background-validation>
<use-fast-fail>true</use-fast-fail>
<stale-connection-checker class-name="org.jboss.jca.adapters.jdbc.extensions.oracle.OracleStaleConnectionChecker"/>
<exception-sorter class-name="org.jboss.jca.adapters.jdbc.extensions.oracle.OracleExceptionSorter"/>
</validation>
<timeout>
<blocking-timeout-millis>15000</blocking-timeout-millis>
<idle-timeout-minutes>1</idle-timeout-minutes>
<query-timeout>30</query-timeout>
</timeout>
</xa-datasource>
<drivers>
<driver name="oracle" module="oracle.jdbc">
<xa-datasource-class>oracle.ucp.jdbc.PoolXADataSourceImpl</xa-datasource-class>
</driver>
</drivers>
</datasources>
</subsystem>
So I could link my SPIs with the secondDatabase:
<spi name="storage">
<provider name="my-spi-with-different-database" enabled="true">
<properties>
<property name="dataSource" value="java:jboss/datasources/secondDatabase"/>
</properties>
</provider>
</spi>
This way, there is only one connection to the database from keycloak and not every SPI - that uses the secondDatabase - has his own connection. So the SPI’s do not get in each others way.
I can’t find a similar solution for Quarkus. Any one else stepped into this problem?
