Configure policy-enforcer to avoid intercepting public urls in keycloak and spring boot
We created a client resource server in keycloak and policies, permissions, scopes for resources, which works well, policy enforcer is used but the only problem that intercepts all requests (endpoint) backend including the public url which restricts and prevents access, wWe created a client resource server in keycloak and policies, permissions, scopes for resources, which works well, policy enforcer is used but the only problem that intercepts all requests (endpoint) backend including the public url which restricts and prevents access, we are new to this issue if anyone can help in indicating how to solve the problem thank you in advance.
this is the file policy-enforcer.json:e are new to this issue if anyone can help in indicating how to solve the problem thank you in advance.
  "realm": "online",
  "auth-server-url": "http://localhost:8182",
  "resource": "client-b",
  "credentials": {
    "secret": "secret"
this is the following code:
@Configuration @EnableWebSecurity public class OAuth2ResourceServerSecurityConfiguration {
@Value("${spring.security.oauth2.resourceserver.jwt.jwk-set-uri}")
String jwkSetUri;
@Bean
public SecurityFilterChain securityFilterChain(HttpSecurity http) throws Exception {
    http
            .authorizeHttpRequests((authorize) -> authorize
                             .requestMatchers("/public/*").permitAll()
                    .anyRequest().authenticated()
            .oauth2ResourceServer(OAuth2ResourceServerConfigurer::jwt)
            .addFilterAfter(createPolicyEnforcerFilter(), BearerTokenAuthenticationFilter.class);
    return http.build();
private ServletPolicyEnforcerFilter createPolicyEnforcerFilter() {
    PolicyEnforcerConfig config;
    try {
        config = JsonSerialization.readValue(getClass().getResourceAsStream("/policy-enforcer.json"), PolicyEnforcerConfig.class);
    } catch (IOException e) {
        throw new RuntimeException(e);
    return new ServletPolicyEnforcerFilter(new ConfigurationResolver() {
        @Override
        public PolicyEnforcerConfig resolve(HttpRequest request) {
            return config;
@Bean
JwtDecoder jwtDecoder() {
    return NimbusJwtDecoder.withJwkSetUri(this.jwkSetUri).build();
The routes were added manually in the file policy-enforcer.json following the keycloak documentation, it was done so that the keycloak resource server only uses the determined urls excluding the public url but it did not work, it still restricts the public url.
  "realm": "online",
  "credentials": {
    "secret": "secret"
  "enforcement-mode" : "ENFORCING",
  "paths": [
      "path" : "/archive/*",
      "methods" : [
          "method": "GET",
          "scopes" : ["urn:client-b:access"]
      "path" : "/send/create",
      "methods" : [
          "method": "POST",
          "scopes" : ["urn:client-b:send:create"]
