I having some trouble understanding the policy enforcement configuration needed in Keycloak and my Spring Boot application in order to have endpoints that are not specified in the application.properties file not be evaluated by the policy enforcer.
Basic case for this is that there are certain resources that are protected and others that are not and could be accessed by anyone.
keycloak.enabled=true
keycloak.ssl-required=external
keycloak.use-resource-role-mappings=false
keycloak.bearer-only=true
keycloak.cors=true
keycloak.security-constraints[0].auth-roles[0]=*
keycloak.security-constraints[0].security-collections[0].patterns[0]=/resource/a/*
keycloak.security-constraints[0].security-collections[0].patterns[1]=/resource/b/*
keycloak.policy-enforcer-config.paths[0].name=a-resources
keycloak.policy-enforcer-config.paths[0].methods[0].method=*
keycloak.policy-enforcer-config.paths[1].name=b-resources
keycloak.policy-enforcer-config.paths[1].methods[0].method=*
keycloak.policy-enforcer-config.enforcement-mode=ENFORCING
keycloak.policy-enforcer-config.lazy-load-paths=true
keycloak config
“allowRemoteResourceManagement”: true,
“policyEnforcementMode”: “ENFORCING”,
“resources”: [
“name”: “a-resources”,
“ownerManagedAccess”: false,
“displayName”: “A Resources”,
“attributes”: {},
“_id”: “60bd3b7e-bd1f-4fb5-b996-ee6e58760411”,
“uris”: [
“/resource/a/"
“name”: “default-resource”,
“displayName”: “Default Resource”,
“attributes”: {},
“_id”: “1fba832e-a601-4b04-9d98-294627cfb154”,
“uris”: [
“name”: “b-resources”,
“displayName”: “B Resources”,
“attributes”: {},
“_id”: “7fc421fb-8e33-4222-9841-0546a606d57e”,
“uris”: [
“/vsa/b/*”
“policies”: [
“id”: “9aff6e2c-1750-4636-b232-9a142cdf3324”,
“name”: “Must be in User group”,
“type”: “group”,
“logic”: “POSITIVE”,
“decisionStrategy”: “UNANIMOUS”,
“config”: {
“groups”: “[{“path”:”/User",“extendChildren”:true}]"
“id”: “fea3d7a5-4024-43d5-aea1-5eec1bc24a33”,
“name”: “A Permissions”,
“type”: “resource”,
“config”: {
“resources”: “[“a-resources”]”,
“applyPolicies”: “[“Must be in User group”]”
“id”: “1202d14d-1ba1-4554-a9af-1a05cc0a8d4a”,
“name”: “B Permissions”,
“type”: “resource”,
“config”: {
“resources”: “[“b-resources”]”,
“scopes”: [],
