I found answers to my Problem online but they do not seem to work for me.
I have an Angular application that redirects for login to my Keycloak server for authentication with OIDC. There I have the option to login with username and password or using SSO with my Identity Provider. The SSO itself works just fine, if I click on it the user gets created in my keycloak database.
The first Problem I faced was trying to login with username and password and I got the following error:
Access to XMLHttpRequest at ‘https://my_keycloak_url/auth/realms/my_realm/protocol/openid-connect/token’ from origin ‘https://my_client_url’ has been blocked by CORS policy: No ‘Access-Control-Allow-Origin’ header is present on the requested resource.
I found the solution to this online and I could solve it by adding https://my_client_url
to the Web origins of my ui-client
However, if I try to login with SSO I get the following error:
Access to XMLHttpRequest at ‘https://my_keycloak_url.de/auth/realms/my_realm/account’ from origin ‘https://my_client_url’ has been blocked by CORS policy: No ‘Access-Control-Allow-Origin’ header is present on the requested resource.
I tried adding https://my_client_url
but that did not work. I also noticed that https://my_keycloak_url.de/auth/realms/my_realm/account
is the base url for my account
and account-console
clients, so I tried adding https://my_client_url
to the Web origins of those clients but it also didn’t work.
Any idea why I’m getting this error?
