I did the initial setup and I setup for remote user , then i configured the server and the realms in the django admin panel and everything looks good. but when i try to Refresh OpenID Connect .well-known I got this error in the image.
In older versions of Keycloak, there used to be auth/ as the first segment of the path. That’s now optional. Given that django-keycloak package you are using hasn’t been updated in a while, my guess is that it’s making an assumption about the paths that is no longer necessarily true.
You could either hunt through the codebase for that, or use the mozilla python OIDC library, which is more mature, recently updated, and has current tutorials for use with recent versions of Keycloak
Thank you so much for your reply.
Yes I tried a lot of ways to change that url but nothing is working I also searched in the django-keycloak files but i couldn’t find anything.
I’m trying to follow this repo but I think I will face the same problem because it was created in 2019.
