File “keystore-client1.py”, line 9, in
creds = oidc_client.client_credentials()
File “/home/jason/anaconda3/lib/python3.8/site-packages/keycloak/openid_connect.py”, line 216, in client_credentials
return self._token_request(grant_type=‘client_credentials’, kwargs)
File “/home/jason/anaconda3/lib/python3.8/site-packages/keycloak/openid_connect.py”, line 296, in _token_request
return self._realm.client.post(self.get_url(‘token_endpoint’),
File “/home/jason/anaconda3/lib/python3.8/site-packages/keycloak/openid_connect.py”, line 36, in get_url
return self.well_known[name]
File “/home/jason/anaconda3/lib/python3.8/site-packages/keycloak/well_known.py”, line 35, in getitem
return self.contents[key]
File “/home/jason/anaconda3/lib/python3.8/site-packages/keycloak/well_known.py”, line 27, in contents
self._contents = self._realm.client.get(self._path)
File “/home/jason/anaconda3/lib/python3.8/site-packages/keycloak/client.py”, line 74, in get
return self._handle_response(
File “/home/jason/anaconda3/lib/python3.8/site-packages/keycloak/client.py”, line 89, in _handle_response
raise KeycloakClientError(original_exc=err)
keycloak.exceptions.KeycloakClientError: 404 Client Error: Not Found for url: https://auth.****./auth/realms/jasonrealm/.well-known/openid-configuration
I am really disappointed the example did not work. Any help is appreciated.
File "keystore-client1.py", line 9, in creds = oidc_client.client_credentials() File "/home/jason/anaconda3/lib/python3.8/site-packages/keycloak/openid_connect.py", line 216, in client_credentials return self._token_request(grant_type='client_credentials', **kwargs) File "/home/jason/anaconda3/lib/python3.8/site-packages/keycloak/openid_connect.py", line 296, in _token_request return self._realm.client.post(self.get_url('token_endpoint'), File "/home/jason/anaconda3/lib/python3.8/site-packages/keycloak/openid_connect.py", line 36, in get_url return self.well_known[name] File "/home/jason/anaconda3/lib/python3.8/site-packages/keycloak/well_known.py", line 35, in __getitem__ return self.contents[key] File "/home/jason/anaconda3/lib/python3.8/site-packages/keycloak/well_known.py", line 27, in contents self._contents = self._realm.client.get(self._path) File "/home/jason/anaconda3/lib/python3.8/site-packages/keycloak/client.py", line 74, in get return self._handle_response( File "/home/jason/anaconda3/lib/python3.8/site-packages/keycloak/client.py", line 89, in _handle_response raise KeycloakClientError(original_exc=err) keycloak.exceptions.KeycloakClientError: 404 Client Error: Not Found for url: https://auth.*********.***/auth/realms/jasonrealm/.well-known/openid-configuration
Looks like the keycloak lib still expects the old keycloak urls (with auth prefix) while your keycloak server is a newer version (>=18) that does not use this prefix by default.
Looking at the code, it seem like the /auth is coing from your config…
We are using version 20 something at the server. In the client I am working with, jason-test-client, I removed the …/auth from the Root URL in the admin console and got the same error. I am using python-keycloak-client v 2.3.0.
