I want a custom startup script to be executed when starting Keycloak in a Docker container.
The script is the following:
embed-host-controller
/socket-binding-group=standard-sockets/socket-binding=jgroups-tcp:write-
attribute(name=interface,value=public)
stop-embedded-host-controller
It can be executed on startup but it fails with the following error message:
Executing cli script: /opt/jboss/startup-scripts/bind-public-interface.cli
"outcome" => "failed",
"failure-description" => {"domain-failure-description" => "WFLYCTL0216: Management resource '[
(\"socket-binding-group\" => \"standard-sockets\"),
(\"socket-binding\" => \"jgroups-tcp\")
]' not found"},
"rolled-back" => true
As far as I understand this should be executed against the default standalone-ha.xml configuration file, in which the nodes already exist.
What am I missing here?
