Hey,
we are in test fase of using offline sessions on a kubernetes environment (2 pods) and with mysql.
We have keycloak version 10.0.2.
For the first time after restart of the kubernetes system we got a duplicate exception, is this a bug i have to report or is it an configuration issue ??
Hope anyone can give advice
2020-11-16 10:55:10,777 WARN [org.hibernate.engine.jdbc.spi.SqlExceptionHelper] (default task-1) SQL Error: 1062, SQLState: 23000
2020-11-16 10:55:10,777 ERROR [org.hibernate.engine.jdbc.spi.SqlExceptionHelper] (default task-1) Duplicate entry ‘4724c969-25fa-4ce7-8fbf-5d9287d40782-ab0218b1-990b-447b-85ae-4c7’ for key ‘PRIMARY’
2020-11-16 10:55:10,778 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (default task-1) Uncaught server error: org.keycloak.models.ModelDuplicateException: javax.persistence.PersistenceException: org.hibernate.exception.ConstraintViolationException: could not execute statement
at org.keycloak.keycloak-model-jpa@10.0.2//org.keycloak.connections.jpa.PersistenceExceptionConverter.convert(PersistenceExceptionConverter.java:57)
at org.keycloak.keycloak-model-jpa@10.0.2//org.keycloak.connections.jpa.PersistenceExceptionConverter.invoke(PersistenceExceptionConverter.java:51)
at javax.persistence.api@2.2.3//com.sun.proxy.$Proxy122.flush(Unknown Source)
at org.keycloak.keycloak-model-jpa@10.0.2//org.keycloak.models.jpa.session.JpaUserSessionPersisterProvider.createClientSession(JpaUserSessionPersisterProvider.java:107)
at org.keycloak.keycloak-services@10.0.2//org.keycloak.services.managers.UserSessionManager.createOfflineClientSession(UserSessionManager.java:154)
at org.keycloak.keycloak-services@10.0.2//org.keycloak.services.managers.UserSessionManager.createOrUpdateOfflineSession(UserSessionManager.java:69)
at org.keycloak.keycloak-services@10.0.2//org.keycloak.protocol.oidc.TokenManager$AccessTokenResponseBuilder.generateRefreshToken(TokenManager.java:782)
at org.keycloak.keycloak-services@10.0.2//org.keycloak.protocol.oidc.endpoints.TokenEndpoint.codeToToken(TokenEndpoint.java:401)
at org.keycloak.keycloak-services@10.0.2//org.keycloak.protocol.oidc.endpoints.TokenEndpoint.processGrantRequest(TokenEndpoint.java:187)
