Hi everyone,
I have a deployment of Keycloak (5 replicas) on kubernetes cluster. It is connected to the Galera MySQL cluster. It has a problem that broke the SQL connection (but afterward the pod still working, not crashing)
I use the Keycloak version 12.0.4 and default standalone.xml config
This is the first part of the log
?[0m?[33m17:25:20,599 WARN [org.hibernate.engine.jdbc.spi.SqlExceptionHelper] (default task-945) SQL Error: 0, SQLState: 08003
?[0m?[31m17:25:20,599 ERROR [org.hibernate.engine.jdbc.spi.SqlExceptionHelper] (default task-945) No operations allowed after connection closed.
?[0m?[0m17:25:20,599 INFO [org.hibernate.event.internal.DefaultLoadEventListener] (default task-945) HHH000327: Error performing load command : org.hibernate.exception.JDBCConnectionException: could not prepare statement
?[0m?[31m17:25:20,600 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (default task-945) Uncaught server error: org.keycloak.models.ModelException: javax.persistence.PersistenceException: org.hibernate.exception.JDBCConnectionException: could not prepare
statement
at org.keycloak.keycloak-model-jpa@12.0.4//org.keycloak.connections.jpa.PersistenceExceptionConverter.convert(PersistenceExceptionConverter.java:61)
at org.keycloak.keycloak-model-jpa@12.0.4//org.keycloak.connections.jpa.PersistenceExceptionConverter.invoke(PersistenceExceptionConverter.java:51)
at javax.persistence.api@2.2.3//com.sun.proxy.$Proxy92.find(Unknown Source)
at org.keycloak.keycloak-model-jpa@12.0.4//org.keycloak.models.jpa.JpaRealmProvider.getClientScopeById(JpaRealmProvider.java:778)
at org.keycloak.keycloak-model-infinispan@12.0.4//org.keycloak.models.cache.infinispan.RealmCacheSession.getClientScopeById(RealmCacheSession.java:1203)
at org.keycloak.keycloak-model-infinispan@12.0.4//org.keycloak.models.cache.infinispan.RealmAdapter.getClientScopeById(RealmAdapter.java:1476)
at org.keycloak.keycloak-server-spi-private@12.0.4//org.keycloak.models.utils.KeycloakModelUtils.findClientScopeById(KeycloakModelUtils.java:608)
at org.keycloak.keycloak-services@12.0.4//org.keycloak.services.util.DefaultClientSessionContext.loadClientScopes(DefaultClientSessionContext.java:192)
at org.keycloak.keycloak-services@12.0.4//org.keycloak.services.util.DefaultClientSessionContext.getClientScopesStream(DefaultClientSessionContext.java:120)
at org.keycloak.keycloak-services@12.0.4//org.keycloak.protocol.oidc.TokenManager.validateToken(TokenManager.java:203)
at org.keycloak.keycloak-services@12.0.4//org.keycloak.protocol.oidc.TokenManager.refreshAccessToken(TokenManager.java:322)
at org.keycloak.keycloak-services@12.0.4//org.keycloak.protocol.oidc.endpoints.TokenEndpoint.refreshTokenGrant(TokenEndpoint.java:548)
at org.keycloak.keycloak-services@12.0.4//org.keycloak.protocol.oidc.endpoints.TokenEndpoint.processGrantRequest(TokenEndpoint.java:221)
at jdk.internal.reflect.GeneratedMethodAccessor525.invoke(Unknown Source)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:138)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.core.ResourceMethodInvoker.internalInvokeOnTarget(ResourceMethodInvoker.java:543)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTargetAfterFilter(ResourceMethodInvoker.java:432)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.core.ResourceMethodInvoker.lambda$invokeOnTarget$0(ResourceMethodInvoker.java:393)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.core.interception.PreMatchContainerRequestContext.filter(PreMatchContainerRequestContext.java:358)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:395)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:364)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invokeOnTargetObject(ResourceLocatorInvoker.java:150)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:110)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invokeOnTargetObject(ResourceLocatorInvoker.java:141)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:104)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:440)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$invoke$4(SynchronousDispatcher.java:229)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.core.SynchronousDispatcher.lambda$preprocess$0(SynchronousDispatcher.java:135)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.core.SynchronousDispatcher.preprocess(SynchronousDispatcher.java:138)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:215)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:245)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:61)
at org.jboss.resteasy.resteasy-jaxrs@3.13.2.Final//org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:56)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:74)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
at org.keycloak.keycloak-wildfly-extensions@12.0.4//org.keycloak.provider.wildfly.WildFlyRequestFilter.lambda$doFilter$0(WildFlyRequestFilter.java:41)
at org.keycloak.keycloak-services@12.0.4//org.keycloak.services.filters.AbstractRequestFilter.filter(AbstractRequestFilter.java:43)
at org.keycloak.keycloak-wildfly-extensions@12.0.4//org.keycloak.provider.wildfly.WildFlyRequestFilter.doFilter(WildFlyRequestFilter.java:39)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.FilterHandler.handleRequest(FilterHandler.java:84)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.ServletChain$1.handleRequest(ServletChain.java:68)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
at org.wildfly.extension.undertow@21.0.2.Final//org.wildfly.extension.undertow.security.SecurityContextAssociationHandler.handleRequest(SecurityContextAssociationHandler.java:78)
at io.undertow.core@2.2.2.Final//io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.RedirectDirHandler.handleRequest(RedirectDirHandler.java:68)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:132)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
at io.undertow.core@2.2.2.Final//io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
at io.undertow.core@2.2.2.Final//io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77)
at io.undertow.core@2.2.2.Final//io.undertow.security.handlers.NotificationReceiverHandler.handleRequest(NotificationReceiverHandler.java:50)
at io.undertow.core@2.2.2.Final//io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
at org.wildfly.extension.undertow@21.0.2.Final//org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
at org.wildfly.extension.undertow@21.0.2.Final//org.wildfly.extension.undertow.deployment.GlobalRequestControllerHandler.handleRequest(GlobalRequestControllerHandler.java:68)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.SendErrorPageHandler.handleRequest(SendErrorPageHandler.java:52)
at io.undertow.core@2.2.2.Final//io.undertow.server.handlers.MetricsHandler.handleRequest(MetricsHandler.java:64)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.core.MetricsChainHandler.handleRequest(MetricsChainHandler.java:59)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:269)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:78)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:133)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:130)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
at org.wildfly.extension.undertow@21.0.2.Final//org.wildfly.extension.undertow.security.SecurityContextThreadSetupAction.lambda$create$0(SecurityContextThreadSetupAction.java:105)
at org.wildfly.extension.undertow@21.0.2.Final//org.wildfly.extension.undertow.deployment.UndertowDeploymentInfoService$UndertowThreadSetupAction.lambda$create$0(UndertowDeploymentInfoService.java:1530)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:249)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:78)
at io.undertow.servlet@2.2.2.Final//io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:99)
at io.undertow.core@2.2.2.Final//io.undertow.server.Connectors.executeRootHandler(Connectors.java:387)
at io.undertow.core@2.2.2.Final//io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:841)
at org.jboss.xnio@3.8.2.Final//org.xnio.XnioWorker$WorkerThreadFactory$1$1.run(XnioWorker.java:1280)
Caused by: javax.persistence.PersistenceException: org.hibernate.exception.JDBCConnectionException: could not prepare statement
at org.hibernate@5.3.20.Final//org.hibernate.internal.ExceptionConverterImpl.convert(ExceptionConverterImpl.java:154)
at org.hibernate@5.3.20.Final//org.hibernate.internal.SessionImpl.find(SessionImpl.java:3545)
at org.hibernate@5.3.20.Final//org.hibernate.internal.SessionImpl.find(SessionImpl.java:3474)
at jdk.internal.reflect.GeneratedMethodAccessor341.invoke(Unknown Source)
at org.keycloak.keycloak-model-jpa@12.0.4//org.keycloak.connections.jpa.PersistenceExceptionConverter.invoke(PersistenceExceptionConverter.java:49)
... 88 more
Caused by: org.hibernate.exception.JDBCConnectionException: could not prepare statement
at org.hibernate@5.3.20.Final//org.hibernate.exception.internal.SQLExceptionTypeDelegate.convert(SQLExceptionTypeDelegate.java:48)
at org.hibernate@5.3.20.Final//org.hibernate.exception.internal.StandardSQLExceptionConverter.convert(StandardSQLExceptionConverter.java:42)
at org.hibernate@5.3.20.Final//org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:113)
at org.hibernate@5.3.20.Final//org.hibernate.engine.jdbc.internal.StatementPreparerImpl$StatementPreparationTemplate.prepareStatement(StatementPreparerImpl.java:186)
at org.hibernate@5.3.20.Final//org.hibernate.engine.jdbc.internal.StatementPreparerImpl.prepareQueryStatement(StatementPreparerImpl.java:151)
at org.hibernate@5.3.20.Final//org.hibernate.loader.plan.exec.internal.AbstractLoadPlanBasedLoader.prepareQueryStatement(AbstractLoadPlanBasedLoader.java:207)
at org.hibernate@5.3.20.Final//org.hibernate.loader.plan.exec.internal.AbstractLoadPlanBasedLoader.executeQueryStatement(AbstractLoadPlanBasedLoader.java:171)
at org.hibernate@5.3.20.Final//org.hibernate.loader.plan.exec.internal.AbstractLoadPlanBasedLoader.executeLoad(AbstractLoadPlanBasedLoader.java:106)
at org.hibernate@5.3.20.Final//org.hibernate.loader.entity.plan.AbstractLoadPlanBasedEntityLoader.load(AbstractLoadPlanBasedEntityLoader.java:191)
at org.hibernate@5.3.20.Final//org.hibernate.persister.entity.AbstractEntityPersister.load(AbstractEntityPersister.java:4289)
at org.hibernate@5.3.20.Final//org.hibernate.event.internal.DefaultLoadEventListener.loadFromDatasource(DefaultLoadEventListener.java:597)
at org.hibernate@5.3.20.Final//org.hibernate.event.internal.DefaultLoadEventListener.doLoad(DefaultLoadEventListener.java:565)
at org.hibernate@5.3.20.Final//org.hibernate.event.internal.DefaultLoadEventListener.load(DefaultLoadEventListener.java:226)
at org.hibernate@5.3.20.Final//org.hibernate.event.internal.DefaultLoadEventListener.proxyOrLoad(DefaultLoadEventListener.java:350)
at org.hibernate@5.3.20.Final//org.hibernate.event.internal.DefaultLoadEventListener.doOnLoad(DefaultLoadEventListener.java:127)
at org.hibernate@5.3.20.Final//org.hibernate.event.internal.DefaultLoadEventListener.onLoad(DefaultLoadEventListener.java:93)
at org.hibernate@5.3.20.Final//org.hibernate.internal.SessionImpl.fireLoadNoChecks(SessionImpl.java:1277)
at org.hibernate@5.3.20.Final//org.hibernate.internal.SessionImpl.fireLoad(SessionImpl.java:1265)
at org.hibernate@5.3.20.Final//org.hibernate.internal.SessionImpl.access$2000(SessionImpl.java:208)
at org.hibernate@5.3.20.Final//org.hibernate.internal.SessionImpl$IdentifierLoadAccessImpl.doLoad(SessionImpl.java:2901)
at org.hibernate@5.3.20.Final//org.hibernate.internal.SessionImpl$IdentifierLoadAccessImpl.load(SessionImpl.java:2875)
at org.hibernate@5.3.20.Final//org.hibernate.internal.SessionImpl.find(SessionImpl.java:3510)
... 93 more
Caused by: java.sql.SQLNonTransientConnectionException: No operations allowed after connection closed.
at com.mysql.jdbc@8.0.22//com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:110)
at com.mysql.jdbc@8.0.22//com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:97)
at com.mysql.jdbc@8.0.22//com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:89)
at com.mysql.jdbc@8.0.22//com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:63)
at com.mysql.jdbc@8.0.22//com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:73)
at com.mysql.jdbc@8.0.22//com.mysql.cj.jdbc.exceptions.SQLExceptionsMapping.translateException(SQLExceptionsMapping.java:73)
at com.mysql.jdbc@8.0.22//com.mysql.cj.jdbc.ConnectionImpl.prepareStatement(ConnectionImpl.java:1667)
at org.jboss.ironjacamar.jdbcadapters@1.4.23.Final//org.jboss.jca.adapters.jdbc.BaseWrapperManagedConnection.doPrepareStatement(BaseWrapperManagedConnection.java:761)
at org.jboss.ironjacamar.jdbcadapters@1.4.23.Final//org.jboss.jca.adapters.jdbc.BaseWrapperManagedConnection.prepareStatement(BaseWrapperManagedConnection.java:747)
at org.jboss.ironjacamar.jdbcadapters@1.4.23.Final//org.jboss.jca.adapters.jdbc.WrappedConnection$4.produce(WrappedConnection.java:483)
at org.jboss.ironjacamar.jdbcadapters@1.4.23.Final//org.jboss.jca.adapters.jdbc.WrappedConnection$4.produce(WrappedConnection.java:481)
at org.jboss.ironjacamar.jdbcadapters@1.4.23.Final//org.jboss.jca.adapters.jdbc.SecurityActions.executeInTccl(SecurityActions.java:98)
at org.jboss.ironjacamar.jdbcadapters@1.4.23.Final//org.jboss.jca.adapters.jdbc.WrappedConnection.prepareStatement(WrappedConnection.java:481)
at org.hibernate@5.3.20.Final//org.hibernate.engine.jdbc.internal.StatementPreparerImpl$5.doPrepare(StatementPreparerImpl.java:149)
at org.hibernate@5.3.20.Final//org.hibernate.engine.jdbc.internal.StatementPreparerImpl$StatementPreparationTemplate.prepareStatement(StatementPreparerImpl.java:176)
... 111 more
Caused by: com.mysql.cj.exceptions.ConnectionIsClosedException: No operations allowed after connection closed.
at com.mysql.jdbc@8.0.22//com.mysql.cj.exceptions.ExceptionFactory.createException(ExceptionFactory.java:61)
at com.mysql.jdbc@8.0.22//com.mysql.cj.exceptions.ExceptionFactory.createException(ExceptionFactory.java:105)
at com.mysql.jdbc@8.0.22//com.mysql.cj.exceptions.ExceptionFactory.createException(ExceptionFactory.java:151)
at com.mysql.jdbc@8.0.22//com.mysql.cj.NativeSession.checkClosed(NativeSession.java:1171)
at com.mysql.jdbc@8.0.22//com.mysql.cj.jdbc.ConnectionImpl.checkClosed(ConnectionImpl.java:576)
at com.mysql.jdbc@8.0.22//com.mysql.cj.jdbc.ConnectionImpl.prepareStatement(ConnectionImpl.java:1598)
... 119 more
Caused by: com.mysql.cj.exceptions.CJCommunicationsException: Communications link failure
Thank you a lot!!!
