Hi everyone,
We are running Keycloak with Postgres DB both in a docker container. Our use case is to have users authenticated towards Active Directory and as an additional factor, the users needs to register a FIDO2 YubiKey Bio device. The Yubikey model was fixed by setting up an “Acceptable AAGUIDs”. On Keycloak we also setup TLS according the official guide Configuring TLS - Keycloak (Providing certificates in PEM format). The certificate was created from a own CA, as the system is isolated from internet.
All was working fine. Then I was asked to setup LDAPS for the connection between Keycloak and Active Directory. I implemented this according the official guide Configuring trusted certificates for outgoing requests - Keycloak with a SPI Truststore. All is still working for the authentication of existing users. But for some reasons, I am not able to register new Yubikeys for any users. Doing so, I am getting the error: “Failed to register your Security key. invalid cert path”
I found out, that this is just the case when having the filter for the Yubikey in place with the setting in “Authentication → Policies → Webauthn Policy → Acceptable AAGUIDs → d8522d9f-575b-4866-88a9-ba99fa02f35b” together with the setting “Authentication → Policies → Webauthn Policy → Attestation conveyance preference → Direct”. When removing this two settings, all works fine but like this, I can not define that only the specific Yubikeys should be accepted.
I have also seen this forum entry, which is somehow the same issue: WebAuthn Register Key Fails, invalid cert path
I tried the solution mentioned there without success.
And in this Red Hat KB the issue sounds the same as well: invalid cert path error while registering WebAuthn authenticator in RH-SSO - Red Hat Customer Portal
I am not sure about the solution mentioned there, as I do not have a RH-SSO truststore at all.
This is my docker compose file I run together with an environment file .env:
version: "3.8"
services:
keycloak:
image: "quay.io/keycloak/keycloak:${KC_VERSION:?err}"
restart: always
command: start-dev
environment:
KC_DB: postgres
KC_DB_URL_HOST: postgres_keycloak
KC_DB_URL_DATABASE: ${POSTGRES_DB}
KC_DB_USERNAME: ${KC_DB_USERNAME}
KC_DB_PASSWORD: ${KC_DB_PASSWORD}
KEYCLOAK_ADMIN: ${KEYCLOAK_ADMIN}
KEYCLOAK_ADMIN_PASSWORD: ${KEYCLOAK_ADMIN_PASSWORD}
KC_HTTPS_CERTIFICATE_FILE: ${KC_HTTPS_CERTIFICATE_FILE}
KC_HTTPS_CERTIFICATE_KEY_FILE: ${KC_HTTPS_CERTIFICATE_KEY_FILE}
KC_SPI_TRUSTSTORE_FILE_FILE: ${KC_SPI_TRUSTSTORE_FILE_FILE}
KC_SPI_TRUSTSTORE_FILE_PASSWORD: ${KC_SPI_TRUSTSTORE_FILE_PASSWORD}
ports:
- ${KC_HTTP_PORT}:8080
- ${KC_HTTPS_PORT}:8443
depends_on:
postgres_keycloak:
condition: service_healthy
volumes:
- ./certs:/etc/ssl/c2i-certs
networks:
- keycloak_network
postgres_keycloak:
image: "postgres:${POSTGRES_VERSION:?err}"
restart: always
volumes:
- ./data/postgresql/data:/var/lib/postgresql/data
environment:
POSTGRES_DB: ${POSTGRES_DB}
POSTGRES_USER: ${KC_DB_USERNAME}
POSTGRES_PASSWORD: ${KC_DB_PASSWORD}
healthcheck:
test: ["CMD", "pg_isready", "-U", "${KC_DB_USERNAME}"]
interval: 10s
start_period: 5s
networks:
- keycloak_network
networks:
keycloak_network:
driver: bridge
I am running keycloak in version 23.0.4.
I have also tried to have TLS enabled with a Java keystore instead of setting the PEM files with the following env variables:
KC_HTTPS_KEY_STORE_FILE: ${KC_HTTPS_KEY_STORE_FILE}
KC_HTTPS_KEY_STORE_PASSWORD: ${KC_HTTPS_KEY_STORE_PASSWORD}
KC_HTTPS_KEY_STORE_TYPE: ${KC_HTTPS_KEY_STORE_TYPE}
And add an additional Java truststore for HTTPS with the following env variables:
KC_HTTPS_TRUST_STORE_FILE: ${KC_HTTPS_TRUST_STORE_FILE}
KC_HTTPS_TRUST_STORE_PASSWORD: ${KC_HTTPS_TRUST_STORE_PASSWORD}
The variables are pointing to the same Trusstore I am using for the SPI Truststore, as the CA Cert is the same that is signing the Active Directory and the keycloak https cert.
This are the logs I am getting from keycloak:
keycloak-keycloak-1 | 2024-01-22 15:14:03,524 DEBUG [org.keycloak.authentication.requiredactions.WebAuthnRegister] (executor-thread-13) invalid cert path: com.webauthn4j.validator.exception.CertificateException: invalid cert path
keycloak-keycloak-1 | at com.webauthn4j.validator.attestation.trustworthiness.certpath.CertPathTrustworthinessValidatorBase.validate(CertPathTrustworthinessValidatorBase.java:66)
keycloak-keycloak-1 | at com.webauthn4j.validator.AttestationValidator.validate(AttestationValidator.java:121)
keycloak-keycloak-1 | at com.webauthn4j.validator.RegistrationDataValidator.validate(RegistrationDataValidator.java:192)
keycloak-keycloak-1 | at com.webauthn4j.WebAuthnRegistrationManager.validate(WebAuthnRegistrationManager.java:209)
keycloak-keycloak-1 | at org.keycloak.authentication.requiredactions.WebAuthnRegister.processAction(WebAuthnRegister.java:238)
keycloak-keycloak-1 | at org.keycloak.services.resources.LoginActionsService.processRequireAction(LoginActionsService.java:1090)
keycloak-keycloak-1 | at org.keycloak.services.resources.LoginActionsService.requiredActionPOST(LoginActionsService.java:1025)
keycloak-keycloak-1 | at org.keycloak.services.resources.LoginActionsService$quarkusrestinvoker$requiredActionPOST_677a8efd4e80bfe1b3aa5a0d6fca2043252c9624.invoke(Unknown Source)
keycloak-keycloak-1 | at org.jboss.resteasy.reactive.server.handlers.InvocationHandler.handle(InvocationHandler.java:29)
keycloak-keycloak-1 | at io.quarkus.resteasy.reactive.server.runtime.QuarkusResteasyReactiveRequestContext.invokeHandler(QuarkusResteasyReactiveRequestContext.java:141)
keycloak-keycloak-1 | at org.jboss.resteasy.reactive.common.core.AbstractResteasyReactiveContext.run(AbstractResteasyReactiveContext.java:145)
keycloak-keycloak-1 | at io.quarkus.vertx.core.runtime.VertxCoreRecorder$14.runWith(VertxCoreRecorder.java:576)
keycloak-keycloak-1 | at org.jboss.threads.EnhancedQueueExecutor$Task.run(EnhancedQueueExecutor.java:2513)
keycloak-keycloak-1 | at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1538)
keycloak-keycloak-1 | at org.jboss.threads.DelegatingRunnable.run(DelegatingRunnable.java:29)
keycloak-keycloak-1 | at org.jboss.threads.ThreadLocalResettingRunnable.run(ThreadLocalResettingRunnable.java:29)
keycloak-keycloak-1 | at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30)
keycloak-keycloak-1 | at java.base/java.lang.Thread.run(Thread.java:840)
keycloak-keycloak-1 | Caused by: java.security.cert.CertPathValidatorException: Path does not chain with any of the trust anchors
keycloak-keycloak-1 | at java.base/sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:157)
keycloak-keycloak-1 | at java.base/sun.security.provider.certpath.PKIXCertPathValidator.engineValidate(PKIXCertPathValidator.java:83)
keycloak-keycloak-1 | at java.base/java.security.cert.CertPathValidator.validate(CertPathValidator.java:309)
keycloak-keycloak-1 | at com.webauthn4j.validator.attestation.trustworthiness.certpath.CertPathTrustworthinessValidatorBase.validate(CertPathTrustworthinessValidatorBase.java:62)
keycloak-keycloak-1 | ... 17 more
keycloak-keycloak-1 | 2024-01-22 15:14:03,525 WARN [org.keycloak.authentication.requiredactions.WebAuthnRegister] (executor-thread-13) webauthn-error-registration
keycloak-keycloak-1 | 2024-01-22 15:14:03,525 DEBUG [org.keycloak.transaction.JtaTransactionWrapper] (executor-thread-13) new JtaTransactionWrapper
keycloak-keycloak-1 | 2024-01-22 15:14:03,526 DEBUG [org.keycloak.transaction.JtaTransactionWrapper] (executor-thread-13) was existing? true
keycloak-keycloak-1 | 2024-01-22 15:14:03,529 DEBUG [org.keycloak.transaction.JtaTransactionWrapper] (executor-thread-13) JtaTransactionWrapper commit
keycloak-keycloak-1 | 2024-01-22 15:14:03,529 DEBUG [org.keycloak.transaction.JtaTransactionWrapper] (executor-thread-13) JtaTransactionWrapper end
keycloak-keycloak-1 | 2024-01-22 15:14:03,529 DEBUG [org.keycloak.transaction.JtaTransactionWrapper] (executor-thread-13) JtaTransactionWrapper resuming suspended
keycloak-keycloak-1 | 2024-01-22 15:14:03,529 WARN [org.keycloak.events] (executor-thread-13) type=CUSTOM_REQUIRED_ACTION_ERROR, realmId=1973b5a6-766b-4834-b182-378e7e4d36cb, clientId=myclient, userId=f:b6aeaed9-71ca-4ebb-8d89-3b8dd7b059f2:demo.mest, ipAddress=172.16.12.3, error=invalid_registration, credential_type=webauthn, auth_method=openid-connect, web_authn_registration_error_detail='invalid cert path', custom_required_action=webauthn-register, response_type=code, web_authn_registration_error=webauthn-error-registration, redirect_uri=https://www.keycloak.org/app/#url=https://keycloak.dev.******/&realm=mest-realm&client=myclient, remember_me=false, code_id=82ac68cb-8eb6-42b7-b5c1-975540e2d632, response_mode=fragment, username=demo.mest
Has anybody some idea, what has to be done to fix this problem?
Thank you very much.
