Hi All,
I think I found a bug in Keycloak-x ftl template loading. Posting here to see if anyone is seeing the same behavior. This is a description of an extension that works fine in Keycloak.
- Place an .ftl template in the
src/main/resorces/theme-resources/templates/
dir of any extension - Create an Authenticator or custom REST endpoint that serves the template, like:
return session.getProvider(LoginFormsProvider.class).createForm("foo.ftl");
- Deploy the extension to the
providers/
dir of Keycloak-x (standard distribution or docker) - Get the following error, where the template cannot be found:
2022-02-07 20:06:27,898 ERROR [org.key.for.log.fre.FreeMarkerLoginFormsProvider] (executor-thread-0) Failed to process template: org.keycloak.theme.FreeMarkerException: Failed to process template foo.ftl
at org.keycloak.theme.FreeMarkerUtil.processTemplate(FreeMarkerUtil.java:71)
at org.keycloak.forms.login.freemarker.FreeMarkerLoginFormsProvider.processTemplate(FreeMarkerLoginFormsProvider.java:512)
at org.keycloak.forms.login.freemarker.FreeMarkerLoginFormsProvider.createForm(FreeMarkerLoginFormsProvider.java:302)
at com.example.FooResourceProvider.foo(FooResourceProvider.java:63)
at io.quarkus.resteasy.runtime.standalone.VertxRequestHandler.dispatch(VertxRequestHandler.java:135)
at io.quarkus.resteasy.runtime.standalone.VertxRequestHandler.handle(VertxRequestHandler.java:81)
at io.quarkus.resteasy.runtime.standalone.VertxRequestHandler.handle(VertxRequestHandler.java:41)
at io.vertx.ext.web.impl.RouteState.handleContext(RouteState.java:1193)
at io.vertx.ext.web.impl.RoutingContextWrapper.next(RoutingContextWrapper.java:201)
at io.quarkus.vertx.http.runtime.VertxHttpRecorder$5.handle(VertxHttpRecorder.java:362)
at io.quarkus.vertx.http.runtime.VertxHttpRecorder$5.handle(VertxHttpRecorder.java:340)
at org.keycloak.quarkus.runtime.integration.web.QuarkusRequestFilter.lambda$createBlockingHandler$1(QuarkusRequestFilter.java:66)
Caused by: freemarker.template.TemplateNotFoundException: Template not found for name "foo.ftl".
The name was interpreted by this TemplateLoader: org.keycloak.theme.FreeMarkerUtil$ThemeTemplateLoader@1e633f79.
at freemarker.template.Configuration.getTemplate(Configuration.java:2883)
at freemarker.template.Configuration.getTemplate(Configuration.java:2703)
at org.keycloak.theme.FreeMarkerUtil.getTemplate(FreeMarkerUtil.java:85)
at org.keycloak.theme.FreeMarkerUtil.processTemplate(FreeMarkerUtil.java:64)
... 52 more
Does anyone have similar problems?
Thanks!
