We need to provide a Login option based upon the following flow:
- Keycloak asks user to login via UUID
- If user with UUID is found then login that user
- If UUID is not found proceed to username & password form
- After user logs in he is required to register a UUID for Login pruposes if he has not done so
First I was looking into the “secret question” example for SPIs, but it looks like there is no way to lookup a credential without a user, or a user with only a credential value.
My current approach would be to try and use an attribute as there a searchForUserByUserAttribute method in UserQueryProvider.
Is that a sensible approach? Are there any examples with a similar usecase?
