Hi Guys!
I am using Keycloak 20.0.1 and using ouath2-proxy in-front of it. There are some issues that i have resolved for our use cases can anyone guide me how can i build a custom image and deploy it on our own nexus repo?
Hi Guys!
It’s very simple to build a custom image.
You just use the Keycloak 20 as your base image, as with any docker image.
use RUN /opt/keycloak/bin/kc.sh build
to run the quarkus optimization and configuration pass, and set your CMD
to 'start --optimized` to skip this phase when using the image.
You can set environment variables inside the image with a ENV
directive (which are more easily overridable when running the image.
You can also copy any necessary files, run any necessary import (like realm import) as a RUN
directive in the dockerfile.
