i wanted to upgrade my local development Keycloak instance to version 17, but can’t get the custom themes to work when started in dev mode. I deploy my custom themes with docker-compose by mounting the theme via a volume into the container. This works flawlessly in version 16, but when using the new Quarkus edition the mounted theme directory is ignored. Does anyone have similar problems?
Thanks!
Update
Found the problem. I used the wrong path. The jboss image is using a different directory structure.
There is a README file in this directory explaining the available options - I also struggled finding documentation about it:
Themes are used to configure the look and feel of login pages and the account management console.
Custom themes packaged in a JAR file should be deployed to the `${kc.home.dir}/providers` directory. After that, run
the `build` command to install them before starting the server.
You are also able to create your custom themes in this directory, directly. Themes within this directory do not require
the `build` command to be installed.
When running the server in development mode using `start-dev`, themes are not cached so that you can easily work on them without a need to restart
the server when making changes.
See the theme section in the [Server Developer Guide](https://www.keycloak.org/docs/latest/server_development/#_themes) for more details about how to create custom themes.
Overriding the built-in templates
While creating custom themes, especially when overriding templates, it may be useful to use the built-in templates as
a reference. These can be found within the theme directory of `../lib/lib/main/org.keycloak.keycloak-themes-17.0.0.jar`, which can be opened using any
standard ZIP archive tool.
You need to package it as a jar for the Quarkus/17 version.
See the README in /opt/keycloak/themes/README.md:
Custom themes packaged in a JAR file should be deployed to the ${kc.home.dir}/providers directory. After that, run
the build command to install them before starting the server.
There‘s no need to package a theme as a jar, I just use regular directory structures, like I did already with KC legacy, and it works flawelessly. Of course you have to use the proper path, but no need for a jar for custom themes.
The contents will depend on what you have chosen to override from the default Keycloak theme. Also make sure your theme directory is readable by Keycloak. For container deployments that means UID 1000 (which is the keycloak user inside the container)
