Issue
We’re unable to upgrade to Keycloak 13.0.
The certificate validation is rejecting our certificate chain with the following error:
java.security.cert.CertPathValidatorException: non-null policy tree required and policy tree is null
Is there a way to use the old validation, or overwrite the validation with our own if Keycloak can’t handle our custom certificates.
I’ve tried to create an SPI for it, but despite the logs saying it’s deployed, it never shows up as an option in the console.
SPI Files:
CustomJavaKeystoreKeyProviderFactory
public class CustomJavaKeystoreKeyProviderFactory extends JavaKeystoreKeyProviderFactory {
private static final Logger logger = Logger.getLogger(CustomJavaKeystoreKeyProviderFactory.class);
@Override
public KeyProvider create(KeycloakSession session, ComponentModel model) {
return new CustomJavaKeystoreKeyProvider(session.getContext().getRealm(), model);
@Override
public void validateConfiguration(KeycloakSession session, RealmModel realm, ComponentModel model) throws ComponentValidationException {
ConfigurationValidationHelper.check(model)
.checkLong(Attributes.PRIORITY_PROPERTY, false)
.checkBoolean(Attributes.ENABLED_PROPERTY, false)
.checkBoolean(Attributes.ACTIVE_PROPERTY, false);
.checkSingle(KEYSTORE_PROPERTY, true)
.checkSingle(KEYSTORE_PASSWORD_PROPERTY, true)
.checkSingle(KEY_ALIAS_PROPERTY, true)
.checkSingle(KEY_PASSWORD_PROPERTY, true);
***** rest of logic *****
@Override
public String getId() {
return "my-java-keystore";
public class CustomJavaKeystoreKeyProvider extends AbstractRsaKeyProvider {
public CustomJavaKeystoreKeyProvider(RealmModel realm, ComponentModel model) {
super(realm, model);
@Override
protected KeyWrapper loadKey(RealmModel realm, ComponentModel model) {
******* logic ****
org.keycloak.keys.KeyProviderFactory
my.key.keycloak.spi.key.CustomJavaKeystoreKeyProviderFactory
Error:
Caused by: java.security.cert.CertPathValidatorException: non-null policy tree required and policy tree is null
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(PKIXMasterCertPathValidator.java:135)
at sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:233)
at sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:141)
at sun.security.provider.certpath.PKIXCertPathValidator.engineValidate(PKIXCertPathValidator.java:80)
at java.security.cert.CertPathValidator.validate(CertPathValidator.java:292)
at JavaKeystoreKeyProviderTest.validateCertificateChain(JavaKeystoreKeyProviderTest.java:106)
at JavaKeystoreKeyProviderTest.loadCertificateChain(JavaKeystoreKeyProviderTest.java:75)
at JavaKeystoreKeyProviderTest.loadKey(JavaKeystoreKeyProviderTest.java:47)
... 1 more
at sun.security.provider.certpath.PolicyChecker.processPolicies(PolicyChecker.java:572)
at sun.security.provider.certpath.PolicyChecker.checkPolicy(PolicyChecker.java:225)
at sun.security.provider.certpath.PolicyChecker.check(PolicyChecker.java:180)
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(PKIXMasterCertPathValidator.java:125)
... 8 more
Picked up JAVA_TOOL_OPTIONS: -Djava.vendor="Sun Microsystems Inc."
