Hi all,
– Update –
It looks like, I can run 12 fine on my PC, using OpenJDK 1.8.0_275 amd64, but not on the server, which has OpenJ9 1.8.0_261 ppc64.
If anyone has any ideas, they would be much appreciated.
– Original –
Keycloak 12 states it can run with OpenJDK 1.8.
But it seems to require module-path in the standalone.sh startup script.
I can’t figure out, how to start it on Java 8, searching the forums for JDK8 or module-path did not yield me much, so I am looking for any clues on how to proceed, as I can’t run JDK higher than 8 on the machine.
What is log output whent you try to start it, and how are you starting it ?
No log output, the java executable simply refuses to start with the arguments given, and -server -mp seem to be the main culprits.
I don’t believe this is a problem of keycloak, but of the java executable running on this system.
I have since been able to install an openj9 jdk-11, and using it specifically to it boot keycloak, and that works.
Edit: I start it using ./bin/standalone.sh
||System||Release ||JDK ||Arch. ||Can run||
|*IBM i* |*7.4* |*OpenJ9 11.0.6-ea** |*ppc64*|*Yes* |
|IBM i |7.4 |OpenJ9 8.261 |ppc64 |No |
|Linux |4.18 |OpenJ9 8.282 |ppc64le|Yes |
|Linux |5.8 |OpenJ9 8.262 |x64 |Yes |
|Linux |5.8 |OpenJ9 8.282 (Current)|x64 |Yes |
|Linux |5.8 |OpenJDK 8 LTS |x64 |Yes |
|Linux |5.8 |OpenJDK 11 LTS |x64 |Yes |
Runtime environments I’ve tested during this.
