Hi all,
I’m trying to configure AWS SSO as an Identity Provider to Keycloak. I’m using the functionality in Keycloak that allows you to update the IdP’s SAML metadata file to prepopulate fields in the Keycloak IdP configuration. They SAML metadata file I was given is below. As you can see, it specifies transient
for the NameIDFormat
, but it doesn’t like that the Principal Type
is still set to Subject NameID
, giving the following error when I try to save the IdP in Keycloak:
Error! Can not have Transient NameID Policy Format together with SUBJECT Principal Type
Does anyone have a suggestion of what I’m doing wrong? I’m sorry, but my SAML expertise is lacking.
<?xml version="1.0" encoding="UTF-8"?><md:EntityDescriptor xmlns:md="urn:oasis:names:tc:SAML:2.0:metadata" entityID="https://portal.sso.us-west-2.amazonaws.com/saml/assertion/NTQ0NDcxNzUzOTUxX2lucy1lNWFkMTgzNWQ2ZDY2N2Ux">
<md:IDPSSODescriptor WantAuthnRequestsSigned="false" protocolSupportEnumeration="urn:oasis:names:tc:SAML:2.0:protocol">
<md:KeyDescriptor use="signing">
<ds:KeyInfo xmlns:ds="http://www.w3.org/2000/09/xmldsig#">
<ds:X509Data>
<ds:X509Certificate>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</ds:X509Certificate>
</ds:X509Data>
</ds:KeyInfo>
</md:KeyDescriptor>
<md:SingleLogoutService Binding="urn:oasis:names:tc:SAML:2.0:bindings:HTTP-POST" Location="https://portal.sso.us-west-2.amazonaws.com/saml/logout/NTQ0NDcxNzUzOTUxX2lucy1lNWFkMTgzNWQ2ZDY2N2Ux"/>
<md:SingleLogoutService Binding="urn:oasis:names:tc:SAML:2.0:bindings:HTTP-Redirect" Location="https://portal.sso.us-west-2.amazonaws.com/saml/logout/NTQ0NDcxNzUzOTUxX2lucy1lNWFkMTgzNWQ2ZDY2N2Ux"/>
<md:NameIDFormat>urn:oasis:names:tc:SAML:2.0:nameid-format:transient</md:NameIDFormat>
<md:SingleSignOnService Binding="urn:oasis:names:tc:SAML:2.0:bindings:HTTP-POST" Location="https://portal.sso.us-west-2.amazonaws.com/saml/assertion/NTQ0NDcxNzUzOTUxX2lucy1lNWFkMTgzNWQ2ZDY2N2Ux"/>
<md:SingleSignOnService Binding="urn:oasis:names:tc:SAML:2.0:bindings:HTTP-Redirect" Location="https://portal.sso.us-west-2.amazonaws.com/saml/assertion/NTQ0NDcxNzUzOTUxX2lucy1lNWFkMTgzNWQ2ZDY2N2Ux"/>
</md:IDPSSODescriptor>
</md:EntityDescriptor>
Thank you and best wishes,
G
