I’m trying to activate Keycloak v17 Infinispan statistics + JMX MBeans.
This link provides Configuring Infinispan caches useful info.
However, i don’t know how to achieve this sentence:
"For embedded caches, you must add the necessary MicroProfile API and provider JARs to your classpath to export Infinispan metrics. "
Is there any documentation how to activate infinispan statistics on Keycloak v17+ ?
Thanks
Simon
I can see that MicroProfile is a Quarkus extension (quarkus/extensions/src/main/java/org/keycloak/provider/quarkus/MicroProfileConfigProvider.java).
Is there a way to activate it ?
Thanks for any help
I followed those posts:
Dockerfile:
FROM quay.io/keycloak/keycloak:17.0.1 as builder
ENV KC_HEALTH_ENABLED=true
ENV KC_METRICS_ENABLED=true
ENV KC_FEATURES=token-exchange
ENV KC_DB=postgres
# Install custom providers
RUN curl -sL https://github.com/aerogear/keycloak-metrics-spi/releases/download/2.5.3/keycloak-metrics-spi-2.5.3.jar -o /opt/keycloak/providers/keycloak-metrics-spi-2.5.3.jar
FROM quay.io/keycloak/keycloak:latest
COPY --from=builder /opt/keycloak/ /opt/keycloak/
WORKDIR /opt/keycloak
# for demonstration purposes only, please make sure to use proper certificates in production instead
RUN keytool -genkeypair -storepass password -storetype PKCS12 -keyalg RSA -keysize 2048 -dname "CN=server" -alias server -ext "SAN:c=DNS:localhost,IP:127.0.0.1" -keystore conf/server.keystore
# change these values to point to a running postgres instance
ENV KC_DB_URL=jdbc:postgresql://x.x.x.x/kcdb
ENV KC_DB_USERNAME=***
ENV KC_DB_PASSWORD=***
ENV KC_HOSTNAME=localhost
ENTRYPOINT ["/opt/keycloak/bin/kc.sh", "start"]
Running the docker:
docker run --name optimized_keycloak -p 8443:8443 -e KEYCLOAK_ADMIN=admin -e KEYCLOAK_ADMIN_PASSWORD=change_me \
-e JAVA_TOOL_OPTIONS="-Dcom.sun.management.jmxremote -Dcom.sun.management.jmxremote.port=8790 -Dcom.sun.management.jmxremote.local.only=false -Dcom.sun.management.jmxremote.authenticate=false -Dcom.sun.management.jmxremote.ssl=false -Dquarkus-log-max-startup-records=10000" \
-p 8790:8790 prebuilt_keycloak
From VisualVM, i log into the JMX console:
Metrics and health are OK.
However, i don’t have access to Infinispan Mbeans.
Thanks for any help
I installed the VisualVM MBeans plugin.
The MBeans tab appears but no Infinispan MBeans.
I have finally been able to activate Infinispan MBeans. Thanks to the following post: config - Configure Infinispan for Keycloak 17 - Stack Overflow.
Here is the cache.xml used:
~ Copyright 2019 Red Hat, Inc. and/or its affiliates
~ and other contributors as indicated by the @author tags.
~ Licensed under the Apache License, Version 2.0 (the "License");
~ you may not use this file except in compliance with the License.
~ You may obtain a copy of the License at
~ http://www.apache.org/licenses/LICENSE-2.0
~ Unless required by applicable law or agreed to in writing, software
~ distributed under the License is distributed on an "AS IS" BASIS,
~ WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
~ See the License for the specific language governing permissions and
~ limitations under the License.
<infinispan
xsi:schemaLocation="urn:infinispan:config:11.0 http://www.infinispan.org/schemas/infinispan-config-11.0.xsd"
xmlns="urn:infinispan:config:11.0">
<cache-container name="keycloak" statistics="true">
<transport lock-timeout="60000"/>
<jmx enabled="true" domain="jboss.datagrid-infinispan"/>
<local-cache name="realms" statistics="true">
<encoding>
</encoding>
<memory max-count="10000"/>
</local-cache>
<local-cache name="users" statistics="true">
<encoding>
</encoding>
</local-cache>
<distributed-cache name="sessions" owners="2" statistics="true">
<expiration lifespan="-1"/>
</distributed-cache>
<distributed-cache name="authenticationSessions" owners="2" statistics="true">
<distributed-cache name="offlineSessions" owners="2" statistics="true">
<distributed-cache name="clientSessions" owners="2" statistics="true">
<distributed-cache name="offlineClientSessions" owners="2" statistics="true">
<distributed-cache name="loginFailures" owners="2" statistics="true">
<local-cache name="authorization" statistics="true">
<encoding>
</encoding>
</local-cache>
<replicated-cache name="work" statistics="true">
</replicated-cache>
<local-cache name="keys">
<encoding>
</encoding>
<memory max-count="1000"/>
</local-cache>
<distributed-cache name="actionTokens" owners="2" statistics="true">
<encoding>
</encoding>
<memory max-count="-1"/>
</cache-container>
</infinispan>
