Infinispan Timeout
Dear All,
We are experiencing a problem with Keycloak communicating with external Infinispan.
The following log shows the error we are facing:
2024-08-29 13:13:53 2024-08-29 10:13:53,137 INFO  [org.infinispan.CONTAINER] (keycloak-cache-init) ISPN000556: Starting user marshaller 'org.infinispan.jboss.marshalling.core.JBossUserMarshaller'
2024-08-29 13:13:53 2024-08-29 10:13:53,339 INFO  [org.keycloak.broker.provider.AbstractIdentityProviderMapper] (main) Registering class org.keycloak.broker.provider.mappersync.ConfigSyncEventListener
2024-08-29 13:13:53 2024-08-29 10:13:53,463 INFO  [org.infinispan.CLUSTER] (keycloak-cache-init) ISPN000078: Starting JGroups channel `ISPN`
2024-08-29 13:13:53 2024-08-29 10:13:53,465 INFO  [org.jgroups.JChannel] (keycloak-cache-init) local_addr: cc49b35e-87f5-413d-8943-aebde564df27, name: authentication-application-3069
2024-08-29 13:13:53 2024-08-29 10:13:53,471 INFO  [org.jgroups.protocols.FD_SOCK2] (keycloak-cache-init) server listening on *.57800
2024-08-29 13:13:53 2024-08-29 10:13:53,537 INFO  [org.infinispan.CLUSTER] (keycloak-cache-init) ISPN000094: Received new cluster view for channel ISPN: [keycloak-infinispan-42737|1] (2) [keycloak-infinispan-42737, authentication-application-3069]
2024-08-29 13:13:53 2024-08-29 10:13:53,940 INFO  [org.infinispan.LIFECYCLE] (jgroups-7,authentication-application-3069) [Context=work] ISPN100002: Starting rebalance with members [keycloak-infinispan-42737, authentication-application-3069], phase READ_OLD_WRITE_ALL, topology id 2
2024-08-29 13:13:53 2024-08-29 10:13:53,942 INFO  [org.infinispan.LIFECYCLE] (non-blocking-thread--p2-t1) [Context=work] ISPN100010: Finished rebalance with members [keycloak-infinispan-42737, authentication-application-3069], topology id 2
2024-08-29 13:13:54 2024-08-29 10:13:54,003 INFO  [org.keycloak.connections.infinispan.DefaultInfinispanConnectionProviderFactory] (main) Node name: authentication-application-3069, Site name: null
2024-08-29 13:13:54 2024-08-29 10:13:54,547 INFO  [io.quarkus] (main) Keycloak 21.1.2 on JVM (powered by Quarkus 2.13.8.Final) started in 3.424s. Listening on: http://0.0.0.0:8080
2024-08-29 13:13:54 2024-08-29 10:13:54,548 INFO  [io.quarkus] (main) Profile prod activated.
2024-08-29 13:13:54 2024-08-29 10:13:54,548 INFO  [io.quarkus] (main) Installed features: [agroal, cdi, hibernate-orm, jdbc-h2, jdbc-mariadb, jdbc-mssql, jdbc-mysql, jdbc-oracle, jdbc-postgresql, keycloak, logging-gelf, micrometer, narayana-jta, reactive-routes, resteasy, resteasy-jackson, smallrye-context-propagation, smallrye-health, vertx]
2024-08-29 13:13:54 2024-08-29 10:13:54,560 ERROR [org.keycloak.services] (main) KC-SERVICES0010: Failed to add user 'admin' to realm 'master': user with username exists
2024-08-29 13:15:12 2024-08-29 10:15:12,049 ERROR [org.infinispan.interceptors.impl.InvocationContextInterceptor] (timeout-thread--p4-t1) ISPN000136: Error executing command RemoveCommand on Cache 'authenticationSessions', writing keys [1f10a011-125e-4691-bec8-4cd2b4909b56]: org.infinispan.util.concurrent.TimeoutException: ISPN000427: Timeout after 15 seconds waiting for acks ([keycloak-infinispan-42737]). Id=50
2024-08-29 13:15:12     at org.infinispan.util.concurrent.CommandAckCollector.createTimeoutException(CommandAckCollector.java:228)
2024-08-29 13:15:12     at org.infinispan.util.concurrent.CommandAckCollector$BaseCollector.call(CommandAckCollector.java:281)
2024-08-29 13:15:12     at org.infinispan.util.concurrent.CommandAckCollector$BaseCollector.call(CommandAckCollector.java:261)
2024-08-29 13:15:12     at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
2024-08-29 13:15:12     at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304)
2024-08-29 13:15:12     at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
2024-08-29 13:15:12     at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
2024-08-29 13:15:12     at java.base/java.lang.Thread.run(Thread.java:833)
2024-08-29 13:15:12
2024-08-29 13:15:27 2024-08-29 10:15:27,058 ERROR [org.infinispan.interceptors.impl.InvocationContextInterceptor] (timeout-thread--p4-t1) ISPN000136: Error executing command PutKeyValueCommand on Cache 'sessions', writing keys [1f10a011-125e-4691-bec8-4cd2b4909b56]: org.infinispan.util.concurrent.TimeoutException: ISPN000427: Timeout after 15 seconds waiting for acks ([keycloak-infinispan-42737]). Id=51
2024-08-29 13:15:27     at org.infinispan.util.concurrent.CommandAckCollector.createTimeoutException(CommandAckCollector.java:228)
2024-08-29 13:15:27     at org.infinispan.util.concurrent.CommandAckCollector$BaseCollector.call(CommandAckCollector.java:281)
2024-08-29 13:15:27     at org.infinispan.util.concurrent.CommandAckCollector$BaseCollector.call(CommandAckCollector.java:261)
2024-08-29 13:15:27     at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
2024-08-29 13:15:27     at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304)
2024-08-29 13:15:27     at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
2024-08-29 13:15:27     at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
2024-08-29 13:15:27     at java.base/java.lang.Thread.run(Thread.java:833)
2024-08-29 13:15:27
2024-08-29 13:15:42 2024-08-29 10:15:42,063 ERROR [org.infinispan.interceptors.impl.InvocationContextInterceptor] (timeout-thread--p4-t1) ISPN000136: Error executing command PutKeyValueCommand on Cache 'clientSessions', writing keys [22a52165-ad0c-4f83-9d84-602c282233bd]: org.infinispan.util.concurrent.TimeoutException: ISPN000427: Timeout after 15 seconds waiting for acks ([authentication-application-3069]). Id=52
2024-08-29 13:15:42     at org.infinispan.util.concurrent.CommandAckCollector.createTimeoutException(CommandAckCollector.java:228)
2024-08-29 13:15:42     at org.infinispan.util.concurrent.CommandAckCollector$BaseCollector.call(CommandAckCollector.java:281)
2024-08-29 13:15:42     at org.infinispan.util.concurrent.CommandAckCollector$BaseCollector.call(CommandAckCollector.java:261)
2024-08-29 13:15:42     at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
2024-08-29 13:15:42     at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304)
2024-08-29 13:15:42     at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
2024-08-29 13:15:42     at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
2024-08-29 13:15:42     at java.base/java.lang.Thread.run(Thread.java:833)
2024-08-29 13:15:42
2024-08-29 13:15:42 2024-08-29 10:15:42,073 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (executor-thread-0) Uncaught server error: org.infinispan.util.concurrent.TimeoutException: ISPN000427: Timeout after 15 seconds waiting for acks ([keycloak-infinispan-42737]). Id=50
2024-08-29 13:15:42     at org.infinispan.interceptors.impl.AsyncInterceptorChainImpl.invoke(AsyncInterceptorChainImpl.java:258)
2024-08-29 13:15:42     at org.infinispan.cache.impl.InvocationHelper.doInvoke(InvocationHelper.java:323)
2024-08-29 13:15:42     at org.infinispan.cache.impl.InvocationHelper.invoke(InvocationHelper.java:111)
2024-08-29 13:15:42     at org.infinispan.cache.impl.InvocationHelper.invoke(InvocationHelper.java:93)
2024-08-29 13:15:42     at org.infinispan.cache.impl.CacheImpl.remove(CacheImpl.java:690)
2024-08-29 13:15:42     at org.infinispan.cache.impl.DecoratedCache.remove(DecoratedCache.java:557)
2024-08-29 13:15:42     at org.infinispan.cache.impl.EncoderCache.remove(EncoderCache.java:723)
2024-08-29 13:15:42     at org.keycloak.models.sessions.infinispan.InfinispanKeycloakTransaction$5.execute(InfinispanKeycloakTransaction.java:194)
2024-08-29 13:15:42     at java.base/java.util.LinkedHashMap$LinkedValues.forEach(LinkedHashMap.java:647)
2024-08-29 13:15:42     at org.keycloak.models.sessions.infinispan.InfinispanKeycloakTransaction.commit(InfinispanKeycloakTransaction.java:58)
2024-08-29 13:15:42     at org.keycloak.services.DefaultKeycloakTransactionManager.commit(DefaultKeycloakTransactionManager.java:146)
2024-08-29 13:15:42     at org.keycloak.services.DefaultKeycloakSession.closeTransactionManager(DefaultKeycloakSession.java:502)
2024-08-29 13:15:42     at org.keycloak.services.DefaultKeycloakSession.close(DefaultKeycloakSession.java:469)
2024-08-29 13:15:42     at org.keycloak.models.utils.KeycloakModelUtils.runJobInRetriableTransaction(KeycloakModelUtils.java:300)
2024-08-29 13:15:42     at org.keycloak.protocol.oidc.endpoints.TokenEndpoint.processGrantRequest(TokenEndpoint.java:178)
2024-08-29 13:15:42     at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
2024-08-29 13:15:42     at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
2024-08-29 13:15:42     at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
2024-08-29 13:15:42     at java.base/java.lang.reflect.Method.invoke(Method.java:568)
2024-08-29 13:15:42     at org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:170)
2024-08-29 13:15:42     at org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:130)
2024-08-29 13:15:42     at org.jboss.resteasy.core.ResourceMethodInvoker.internalInvokeOnTarget(ResourceMethodInvoker.java:660)
2024-08-29 13:15:42     at org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTargetAfterFilter(ResourceMethodInvoker.java:524)
2024-08-29 13:15:42     at org.jboss.resteasy.core.ResourceMethodInvoker.lambda$invokeOnTarget$2(ResourceMethodInvoker.java:474)
2024-08-29 13:15:42     at org.jboss.resteasy.core.interception.jaxrs.PreMatchContainerRequestContext.filter(PreMatchContainerRequestContext.java:364)
2024-08-29 13:15:42     at org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:476)
2024-08-29 13:15:42     at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:434)
2024-08-29 13:15:42     at org.jboss.resteasy.core.ResourceLocatorInvoker.invokeOnTargetObject(ResourceLocatorInvoker.java:192)
2024-08-29 13:15:42     at org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:152)
2024-08-29 13:15:42     at org.jboss.resteasy.core.ResourceLocatorInvoker.invokeOnTargetObject(ResourceLocatorInvoker.java:183)
2024-08-29 13:15:42     at org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:141)
2024-08-29 13:15:42     at org.jboss.resteasy.core.ResourceLocatorInvoker.invoke(ResourceLocatorInvoker.java:32)
2024-08-29 13:15:42     at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:492)
2024-08-29 13:15:42     at org.jboss.resteasy.core.SynchronousDispatcher.lambda$invoke$4(SynchronousDispatcher.java:261)
2024-08-29 13:15:42     at org.jboss.resteasy.core.SynchronousDispatcher.lambda$preprocess$0(SynchronousDispatcher.java:161)
2024-08-29 13:15:42     at org.jboss.resteasy.core.SynchronousDispatcher.preprocess(SynchronousDispatcher.java:164)
2024-08-29 13:15:42     at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:247)
2024-08-29 13:15:42     at io.quarkus.resteasy.runtime.standalone.RequestDispatcher.service(RequestDispatcher.java:73)
2024-08-29 13:15:42     at io.quarkus.resteasy.runtime.standalone.VertxRequestHandler.dispatch(VertxRequestHandler.java:151)
2024-08-29 13:15:42     at io.quarkus.resteasy.runtime.standalone.VertxRequestHandler.handle(VertxRequestHandler.java:82)
2024-08-29 13:15:42     at io.quarkus.resteasy.runtime.standalone.VertxRequestHandler.handle(VertxRequestHandler.java:42)
2024-08-29 13:15:42     at io.vertx.ext.web.impl.RouteState.handleContext(RouteState.java:1284)
2024-08-29 13:15:42     at io.vertx.ext.web.impl.RoutingContextImplBase.iterateNext(RoutingContextImplBase.java:173)
2024-08-29 13:15:42     at io.vertx.ext.web.impl.RoutingContextImpl.next(RoutingContextImpl.java:140)
2024-08-29 13:15:42     at io.quarkus.vertx.http.runtime.StaticResourcesRecorder$2.handle(StaticResourcesRecorder.java:84)
2024-08-29 13:15:42     at io.quarkus.vertx.http.runtime.StaticResourcesRecorder$2.handle(StaticResourcesRecorder.java:71)
2024-08-29 13:15:42     at io.quarkus.vertx.http.runtime.VertxHttpRecorder$6.handle(VertxHttpRecorder.java:430)
2024-08-29 13:15:42     at io.quarkus.vertx.http.runtime.VertxHttpRecorder$6.handle(VertxHttpRecorder.java:408)
2024-08-29 13:15:42     at org.keycloak.quarkus.runtime.integration.web.QuarkusRequestFilter.lambda$createBlockingHandler$0(QuarkusRequestFilter.java:82)
2024-08-29 13:15:42     at io.quarkus.vertx.core.runtime.VertxCoreRecorder$14.runWith(VertxCoreRecorder.java:576)
2024-08-29 13:15:42     at org.jboss.threads.EnhancedQueueExecutor$Task.run(EnhancedQueueExecutor.java:2449)
2024-08-29 13:15:42     at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1478)
2024-08-29 13:15:42     at org.jboss.threads.DelegatingRunnable.run(DelegatingRunnable.java:29)
2024-08-29 13:15:42     at org.jboss.threads.ThreadLocalResettingRunnable.run(ThreadLocalResettingRunnable.java:29)
2024-08-29 13:15:42     at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30)
2024-08-29 13:15:42 Caused by: org.infinispan.util.concurrent.TimeoutException: ISPN000427: Timeout after 15 seconds waiting for acks ([keycloak-infinispan-42737]). Id=50
2024-08-29 13:15:42     ... 1 more
2024-08-29 13:15:42     Suppressed: org.infinispan.commons.util.logging.TraceException
2024-08-29 13:15:42             at org.infinispan.interceptors.impl.SimpleAsyncInvocationStage.get(SimpleAsyncInvocationStage.java:39)
2024-08-29 13:15:42             at org.infinispan.interceptors.impl.AsyncInterceptorChainImpl.invoke(AsyncInterceptorChainImpl.java:249)
The topology we have is based on Docker containers for the development of the security service.
For Keycloak:
We have built an image, with 21.1.2 version, containing the following XML file (cache-ispn-remote.xml) to configure the internal Infinispan:
<infinispan
  xsi:schemaLocation="urn:infinispan:config:14.0 http://www.infinispan.org/schemas/infinispan-config-14.0.xsd"
  xmlns="urn:infinispan:config:14.0">
        <!--        <transport lock-timeout="60000" stack="jdbc-ping-tcp"/>-->
    <transport lock-timeout="60000"/>
        <local-cache name="realms">
            <encoding>
            </encoding>
            <memory max-count="10000"/>
        </local-cache>
        <local-cache name="users">
            <encoding>
            </encoding>
        </local-cache>
            <remote-store xmlns="urn:infinispan:config:store:remote:14.0"
                          cache="sessions"
                          purge="false"
                          preload="false"
                          shared="true"
                          segmented="false"
                          raw-values="true"
                          connect-timeout="5000">
                <remote-server host="${infinispan.bind.address:127.0.0.1}"
                               port="${infinispan.bind.port:11222}"/>
                <security>
                    <authentication server-name="infinispan">
                        <digest username="keycloak"
                                password="keycloak"
                                realm="default"/>
                    </authentication>
                </security>
            </remote-store>
            <expiration lifespan="-1"/>
        </distributed-cache>
                          cache="authenticationSessions"
                          purge="false"
                          preload="false"
                          shared="true"
                          segmented="false"
                          raw-values="true"
                <security>
                                password="keycloak"
                                realm="default"/>
                    </authentication>
                </security>
            </remote-store>
                          cache="offlineSessions"
                          purge="false"
                          preload="false"
                          shared="true"
                          segmented="false"
                          raw-values="true"
                <security>
                                password="keycloak"
                                realm="default"/>
                    </authentication>
                </security>
            </remote-store>
                          cache="clientSessions"
                          purge="false"
                          preload="false"
                          shared="true"
                          segmented="false"
                          raw-values="true"
                <security>
                                password="keycloak"
                                realm="default"/>
                    </authentication>
                </security>
            </remote-store>
                          cache="offlineClientSessions"
                          purge="false"
                          preload="false"
                          shared="true"
                          segmented="false"
                          raw-values="true"
                <security>
                                password="keycloak"
                                realm="default"/>
                    </authentication>
                </security>
            </remote-store>
                          cache="loginFailures"
                          purge="false"
                          preload="false"
                          shared="true"
                          segmented="false"
                          raw-values="true"
                <security>
                                password="keycloak"
                                realm="default"/>
                    </authentication>
                </security>
            </remote-store>
            <encoding>
            </encoding>
        </local-cache>
                          cache="work"
                          purge="false"
                          preload="false"
                          shared="true"
                          segmented="false"
                          raw-values="true"
                <security>
                                password="keycloak"
                                realm="default"/>
                    </authentication>
                </security>
            </remote-store>
        </replicated-cache>
        <local-cache name="keys">
            <encoding>
            </encoding>
            <memory max-count="1000"/>
        </local-cache>
                          cache="actionTokens"
                          purge="false"
                          preload="false"
                          shared="true"
                          segmented="false"
                          raw-values="true"
                <security>
                                password="keycloak"
                                realm="default"/>
                    </authentication>
                </security>
            </remote-store>
            <encoding>
            </encoding>
            <memory max-count="-1"/>
    </cache-container>
</infinispan>
And we run it with the following properties:
		"Ports": {
			"8080/tcp": [
					"HostIp": "0.0.0.0",
					"HostPort": "8090"
			"8443/tcp": null,
			"8787/tcp": [
					"HostPort": "8797"
		"Env": [
			"KC_DB_PASSWORD=keycloak",
			"KEYCLOAK_ADMIN_PASSWORD=U6cDQm4Wy8vCd!BbSAEZ5#",
			"KC_CACHE=ispn",
			"KC_CACHE_REMOTE_USERNAME=keycloak",
			"KC_DB=mysql",
			"KC_HOSTNAME=host.docker.internal",
			"KEYCLOAK_ADMIN=admin",
			"KC_HEALTH_ENABLED=true",
			"KC_CACHE_CONFIG_FILE=cache-ispn-remote.xml",
			"KC_CACHE_REMOTE_TLS_ENABLED=false",
			"KC_LOG_LEVEL=INFO",
			"KC_DB_URL=jdbc:mysql://host.docker.internal:3317/keycloak",
			"KC_DB_USERNAME=keycloak",
			"KC_CACHE_STACK=tcp",
			"KC_CACHE_REMOTE_PORT=11222",
			"DEBUG_PORT=*:8787",
			"KC_CACHE_REMOTE_HOST=host.docker.internal",
			"KC_CACHE_REMOTE_PASSWORD=keycloak",
			"PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
			"LANG=en_US.UTF-8",
			"KEYCLOAK_PRODUCTION=true",
			"KEYCLOAK_ENABLE_HTTPS=false",
			"KC_HOSTNAME_STRICT=false",
			"KC_HOSTNAME_STRICT_HTTPS=false",
			"KC_HTTP_ENABLED=true",
			"KC_METRICS_ENABLED=true",
			"KC_FEATURES=token-exchange"
		"Cmd": [
			"start",
			"--optimized",
			"--debug"
For Infinispan:
We have built an image, with 14.0.9.Final version, that contains the following XML file (infinispan.xml) for its configuration:
We have added the following dependencies:
  • keycloak-core-21.1.2.jar
  • keycloak-model-infinispan-21.1.2.jar
  • keycloak-server-spi-21.1.2.jar
  • keycloak-server-spi-private-21.1.2.jar
		"Ports": {
			"11221/tcp": null,
			"11222/tcp": [
					"HostPort": "11222"
			"11223/tcp": null,
			"2157/tcp": null,
			"46655/tcp": null,
			"57600/tcp": null,
			"7800/tcp": null,
			"7900/tcp": null,
			"8080/tcp": null,
			"8443/tcp": null
		"Env": [
			"USER=keycloak",
			"PASS=keycloak",
			"container=oci",
			"HOME=/home/jboss",
			"JAVA_HOME=/usr/lib/jvm/jre",
			"JAVA_VENDOR=openjdk",
			"JAVA_VERSION=17",
			"JBOSS_CONTAINER_OPENJDK_JRE_MODULE=/opt/jboss/container/openjdk/jre",
			"JBOSS_CONTAINER_JAVA_PROXY_MODULE=/opt/jboss/container/java/proxy",
			"JBOSS_CONTAINER_JAVA_JVM_MODULE=/opt/jboss/container/java/jvm",
			"JBOSS_CONTAINER_UTIL_LOGGING_MODULE=/opt/jboss/container/util/logging/",
			"JAVA_DATA_DIR=/deployments/data",
			"JBOSS_CONTAINER_JAVA_RUN_MODULE=/opt/jboss/container/java/run",
			"JBOSS_IMAGE_NAME=infinispan/server",
			"JBOSS_IMAGE_VERSION=14.0.9.Final-1",
			"LANG=C.utf8",
			"ISPN_HOME=/opt/infinispan",
			"JAVA_GC_MAX_METASPACE_SIZE=96m",
			"JAVA_GC_METASPACE_SIZE=32m",
			"JAVA_MAX_MEM_RATIO=50"
		"Cmd": [
			"-c",
			"/keycloak-config/infinispan.xml"
We have also tried using the basic settings for UDP Transport stacks, but it ends up with the same error.
Looking forward to your feedback
Thanks in advance,
Aris
And the infinispan.xml file:
<infinispan
  xsi:schemaLocation="urn:infinispan:config:14.0 https://infinispan.org/schemas/infinispan-config-14.0.xsd
                        urn:infinispan:server:14.0 https://infinispan.org/schemas/infinispan-server-14.0.xsd"
  xmlns:server="urn:infinispan:server:14.0">
    <cache-container name="default" statistics="true">
        <transport
          cluster="${infinispan.cluster.name:ISPN}"
          stack="${infinispan.cluster.stack:tcp}"
          node-name="${infinispan.node.name:}"
        <security>
            <authorization/>
        </security>
        <serialization marshaller="org.infinispan.jboss.marshalling.commons.GenericJBossMarshaller">
            <allow-list>
                <class>org.*</class>
                <regex>.*</regex>
            </allow-list>
        </serialization>
            <encoding>
                <key media-type="application/x-jboss-marshalling"/>
                <value media-type="application/x-jboss-marshalling"/>
            </encoding>
            <expiration lifespan="900000000000000000"/>
            <encoding>
            </encoding>
            <encoding>
            </encoding>
            <encoding>
            </encoding>
            <encoding>
            </encoding>
            <encoding>
            </encoding>
            <encoding>
            </encoding>
        </replicated-cache>
            <encoding>
            </encoding>
            <expiration interval="300000"/>
    </cache-container>
    <server xmlns="urn:infinispan:server:14.0">
        <interfaces>
            <interface name="public">
                <inet-address value="${infinispan.bind.address:127.0.0.1}"/>
            </interface>
        </interfaces>
        <socket-bindings default-interface="public"
                         port-offset="${infinispan.socket.binding.port-offset:0}">
            <socket-binding name="default" port="${infinispan.bind.port:11222}"/>
            <socket-binding name="memcached" port="11221"/>
        </socket-bindings>
        <security>
            <credential-stores>
                <credential-store name="credentials" path="credentials.pfx">
                    <clear-text-credential clear-text="secret"/>
                </credential-store>
            </credential-stores>
            <security-realms>
                <security-realm name="default">
                    <!-- Uncomment to enable TLS on the realm -->
                  <!-- server-identities>
           <ssl>
              <keystore path="application.keystore"
                        password="password" alias="server"
                        generate-self-signed-certificate-host="localhost"/>
           </ssl>
        </server-identities-->
                  <properties-realm groups-attribute="Roles">
                        <user-properties path="users.properties"/>
                        <group-properties path="groups.properties"/>
                    </properties-realm>
                </security-realm>
            </security-realms>
        </security>
        <endpoints socket-binding="default" security-realm="default">
            <endpoint>
                <hotrod-connector name="hotrod">
                    <authentication>
                        <sasl mechanisms="DIGEST-MD5"
                              server-name="infinispan"/>
                    </authentication>
                </hotrod-connector>
                <rest-connector name="rest"/>
            </endpoint>
        </endpoints>
    </server>
</infinispan>
