Invalid_code when authenticating through reverse proxy
I’m trying to setup a docker instance of keycloak behind a reverse proxy that simply forward each request to him.
I already set up the proxy to add
X-Forwarded-For
X-Forwarded-Proto
headers with the IP of the client and “http” values.
I also set up the env variable of the docker instance PROXY_ADDRESS_FORWARDING: “true”.
I’m trying now to authenticate trough the javascript client, but I got this error (I enabled debug log level for keycloak)
keycloak                      | 15:50:01,116 DEBUG [org.keycloak.services.resources.SessionCodeChecks] (default task-1) Will use client 'Webgui' in back-to-application link
keycloak                      | 15:50:01,116 DEBUG [org.keycloak.services.util.CookieHelper] (default task-1) {1} cookie found in the requests header
keycloak                      | 15:50:01,116 DEBUG [org.keycloak.services.util.CookieHelper] (default task-1) Couldnt find any cookies with name AUTH_SESSION_ID, trying AUTH_SESSION_ID_LEGACY
keycloak                      | 15:50:01,117 DEBUG [org.keycloak.services.managers.AuthenticationSessionManager] (default task-1) Not found AUTH_SESSION_ID cookie
keycloak                      | 15:50:01,117 DEBUG [org.keycloak.services.util.CookieHelper] (default task-1) {1} cookie found in the requests header
keycloak                      | 15:50:01,118 DEBUG [org.keycloak.services.util.CookieHelper] (default task-1) Couldnt find any cookies with name AUTH_SESSION_ID, trying AUTH_SESSION_ID_LEGACY
keycloak                      | 15:50:01,118 DEBUG [org.keycloak.services.util.CookieHelper] (default task-1) {1} cookie found in the requests header
keycloak                      | 15:50:01,127 DEBUG [org.keycloak.services.managers.AuthenticationSessionManager] (default task-1) Not found AUTH_SESSION_ID cookie
keycloak                      | 15:50:01,127 DEBUG [org.keycloak.services.util.CookieHelper] (default task-1) {1} cookie found in the requests header
keycloak                      | 15:50:01,127 DEBUG [org.keycloak.services.util.CookieHelper] (default task-1) Couldnt find any cookies with name AUTH_SESSION_ID, trying AUTH_SESSION_ID_LEGACY
keycloak                      | 15:50:01,128 DEBUG [org.keycloak.services.managers.AuthenticationSessionManager] (default task-1) Not found AUTH_SESSION_ID cookie
keycloak                      | 15:50:01,128 DEBUG [org.keycloak.services.resources.SessionCodeChecks] (default task-1) Authentication session not found. Trying to restart from cookie.
keycloak                      | 15:50:01,128 DEBUG [org.keycloak.protocol.RestartLoginCookie] (default task-1) KC_RESTART cookie doesn't exist
keycloak                      | 15:50:01,129 WARN  [org.keycloak.events] (default task-1) type=LOGIN_ERROR, realmId=test, clientId=null, userId=null, ipAddress=172.18.0.1, error=invalid_code
I checked the URL encoding and can confirm that the uri string sent by the proxy is the same as when it leaves the client.
Any help will be appreciated
Please find compared the tcpdump of the request before and after the reverse proxy:
BEFORE
POST /auth/realms/test/login-actions/authenticate?session_code=cXM4QygbthFizJ1jqGaTOctRZKR7WhU-o6tw1dYwrMM&execution=ddf78420-3ed6-477f-9bba-14e1c0afc78e&client_id=Webgui&tab_id=n20mqnfLMD0 HTTP/1.1
Host: localhost:8199
Connection: keep-alive
Content-Length: 43
Pragma: no-cache
Cache-Control: no-cache
Upgrade-Insecure-Requests: 1
Origin: http://localhost:8199
Content-Type: application/x-www-form-urlencoded
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9
Sec-Fetch-Site: same-origin
Sec-Fetch-Mode: navigate
Sec-Fetch-User: ?1
Sec-Fetch-Dest: document
Referer: http://localhost:8199/auth/realms/test/protocol/openid-connect/auth?client_id=Webgui&redirect_uri=http%3A%2F%2Flocalhost%3A3000%2F&state=64a47edf-1f21-4881-bf91-eb803ff799a1&response_mode=fragment&response_type=code&scope=openid&nonce=6e378e5c-796b-482e-91d0-924fffade91b
Accept-Encoding: gzip, deflate, br
Accept-Language: it-IT,it;q=0.9,en-US;q=0.8,en;q=0.7
Cookie: _xsrf=2|5c6a380b|2939d9bf43d7bf802f3a86f4c0884f29|1597236136
username=admin&password=admin&credentialId=
AFTER
Content-Length: 43
Pragma: no-cache
Sec-Fetch-User: ?1
X-Forwarded-For: 172.18.0.1
X-Forwarded-Proto: http
I’ve also been able to allign Accept-Encoding header by tuning the proxy. Now the two requests are aligned.
Still I get the same error from keycloak.
Please find also the definition of keyclock in my docker-compose file:
keycloak:
image: jboss/keycloak:11.0.0
container_name: keycloak
hostname: keycloak
ports:
- “8080:8080”
environment:
KEYCLOAK_USER: admin
KEYCLOAK_PASSWORD: admin
DB_VENDOR: postgres
DB_ADDR: postgres11-keycloak
DB_PORT: 5432
DB_DATABASE: keycloak
DB_USER: postgres
DB_PASSWORD: postgres
depends_on:
- postgres11-keycloak
networks:
- keycloak-network
- backend
I finally ended up solving my issues. Thanks to jinnerbichler I discovered that more than the two headers indicated in the documentation (X-Forwarded-For, X-Forwarded-Proto) need to be set by the proxy.
The working solution includes:
X-Forwarded-For
X-Forwarded-Proto
X-Forwarded-Host
X-Forwarded-Server
X-Forwarded-Port
X-Real-IP
Please update the documentation accordingly, should you agree on this solution.
Cheers
