I’m running Keycloak on a docker container on port 8080 and i use Nginx as reverse proxy to match the hostname ‘auth.local’. When i go to auth.local and i log in, i get a “Cookie error” ( error=“cookie_not_found” in docker logs ).
Below, there is my docker-compose and nginx conf (template) :
version: '3.9'
services:
webserver:
container_name: webserver
image: nginx:latest
ports :
- "80:80"
restart: unless-stopped
environment :
- SERVER_NAME=local
volumes:
- ./logs:/var/log/nginx/
- ./webserver/templates:/etc/nginx/templates
keycloak:
container_name: keycloak
image: quay.io/keycloak/keycloak
environment:
- KEYCLOAK_ADMIN=admin
- KEYCLOAK_ADMIN_PASSWORD=admin
- KC_DB=postgres
- KC_DB_URL=jdbc:postgresql://172.17.0.1:5432/keycloak
- KC_DB_PASSWORD=keycloak
- KC_DB_USERNAME=keycloak
- KC_HOSTNAME=auth.local
- KC_PROXY_ADDRESS_FORWARDING=true
- KC_HOSTNAME_STRICT=false
command:
- start-dev
server{
listen 80;
server_name auth.${SERVER_NAME};
location / {
proxy_pass http://keycloak:8080/;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Server $host;
What I can’t understand is that when I don’t proxie the service, I can correctly connect to the admin console.
What configuration did I do wrong?
Thanks !
