I’m trying to install keycloak on my Win10 machine, running with a JDK 11.0.9 downloaded directly from the Oracle website.
When trying to execute .\kc.bat start-dev to try Keycloak out, I get the following error :
java.nio.charset.UnsupportedCharsetException: cp65001
at java.base/java.nio.charset.Charset.forName(Charset.java:529)
at picocli.CommandLine.getStdoutEncoding(CommandLine.java:14527)
at picocli.CommandLine.getOut(CommandLine.java:1209)
at picocli.CommandLine.executeHelpRequest(CommandLine.java:1915)
at picocli.CommandLine.executeHelpRequest(CommandLine.java:1909)
at picocli.CommandLine$AbstractParseResultHandler.execute(CommandLine.java:2176)
at picocli.CommandLine$RunLast.execute(CommandLine.java:2316)
at picocli.CommandLine.execute(CommandLine.java:2078)
at org.keycloak.quarkus.runtime.cli.Picocli.parseAndRun(Picocli.java:84)
at org.keycloak.quarkus.runtime.KeycloakMain.main(KeycloakMain.java:79)
at io.quarkus.bootstrap.runner.QuarkusEntryPoint.doRun(QuarkusEntryPoint.java:60)
at io.quarkus.bootstrap.runner.QuarkusEntryPoint.main(QuarkusEntryPoint.java:31)
Do you know what may be causing this issue ?
Thank you
