I am unable to trigger KC to import a realm using the KEYCLOAK_IMPORT environment variable when using Docker / Docker Compose.
I have previously logged into the KC admin tool, created a realm, and successfully exported the realm’s JSON. I can go into KC using the admin tool, and import the JSON successfully via the CREATE REALM import option in the KC admin tool.
I am unable to import / create this realm, from the previously exported JSON file, when I start KC using Docker / Docker Compose. I am using keycloak:latest and the KEYCLOAK_IMPORT environment variable.
DockerFile (incomplete - shows copying realm JSON to container
COPY /config/instrument_interface_realm.json /tmp/instrument_interface_realm.json
Docker Compose:
build: keycloak
environment:
- KEYCLOAK_ADMIN=admin
- KEYCLOAK_ADMIN_PASSWORD=xxxxxxxxxxxxxxx
- KC_ENV
- KEYCLOAK_IMPORT=/tmp/instrument_interface_realm.json
ports:
- "8081:8080"
Docker Startup Command:
/opt/keycloak/bin/kc.sh start-dev
Additional Info:
- The file is successfully copied to the container and exists at /tmp/instrument_interface_realm.json.
- I can shell into the running container and see that the KEYCLOAK_IMPORT environment is properly set.
The KC container starts up successfully but the realm is never imported. There is nothing in the logs that indicates KC even attempts an import.
I am unable to locate any other information that I might be missing. Does anyone have any insights? Thanks in advance!
