I use keycloak 18 with the version with wildfly. What is the option to set to have the compatibility corresponding to the directive spi-login-protocol-openid-connect-legacy-logout-redirect-uri which is available for keycloak quarkus distribution?
Thanks
I didn’t test it, but from the naming convention I deviate something like this as JBOSS-CLI command:
/subsystem=keycloak-server/spi=login-protocol:add
/subsystem=keycloak-server/spi=login-protocol/provider=openid-connect:add(enabled=true)
/subsystem=keycloak-server/spi=login-protocol/provider=openid-connect:write-attribute(name=properties.legacy-logout-redirect-uri,value=true)
which should result in an entry in standalone(-ha).xml
in the keycloak-server
subsystem like this:
<spi name="login-protocol">
<provider name="openid-connect" enabled="true">
<properties>
<property name="legacy-logout-redirect-uri" value="true"/>
</properties>
</provider>
</spi>
It works.
Thanks !
Does the backwards compat setting also work with the new params? Meaning it would be compatable so we can use it to send just the rediret or post_log_outredirect with the id_hint
