we have a problem with a fresh Keycloak 20 installation. Everything seems to work fine, but if you try to enable fine grained permissions for users in a realm, it results in a NullPointerException.
Is there anything we can do or does anyone have the same problem?
OS is Debian 11 with default-jre.
ERROR [org.keycloak.services.error.KeycloakErrorHandler] (executor-thread-29) Uncaught server error: java.lang.NullPointerException
at org.keycloak.services.resources.admin.RealmAdminResource.toUsersMgmtRef(RealmAdminResource.java:521)
at org.keycloak.services.resources.admin.RealmAdminResource.setUsersManagementPermissionsEnabled(RealmAdminResource.java:511)
at io.vertx.ext.web.impl.RouteState.handleContext(RouteState.java:1284)
at io.vertx.ext.web.impl.RoutingContextImplBase.iterateNext(RoutingContextImplBase.java:173)
at io.vertx.ext.web.impl.RoutingContextImpl.next(RoutingContextImpl.java:140)
at io.quarkus.vertx.http.runtime.StaticResourcesRecorder$2.handle(StaticResourcesRecorder.java:84)
at io.quarkus.vertx.http.runtime.StaticResourcesRecorder$2.handle(StaticResourcesRecorder.java:71)
at io.quarkus.vertx.http.runtime.VertxHttpRecorder$6.handle(VertxHttpRecorder.java:430)
at io.quarkus.vertx.http.runtime.VertxHttpRecorder$6.handle(VertxHttpRecorder.java:408)
at org.keycloak.quarkus.runtime.integration.web.QuarkusRequestFilter.lambda$createBlockingHandler$0(QuarkusRequestFilter.java:82)
at io.quarkus.vertx.core.runtime.VertxCoreRecorder$14.runWith(VertxCoreRecorder.java:564)
