Dear Prof ,
I need help , I am stuck on this issue for a while ,
my domain mydomain is secured , we are using load balancer to offloading the certificates and behind load balancer I have my nginx server with multiple locations , everything working smoothly accept my sso location that redirect me to my keycloak server , here is my nginx conf :
location /sso/ {
proxy_set_header Host $http_host; # to forward the original host requested by the client
proxy_set_header X-Forwarded-For $http_x_forwarded_for; # To forward the original client's IP address
proxy_set_header X-Forwarded-Proto https; # to forward the original protocol (HTTP or HTTPS)
proxy_set_header X-Forwarded-By $server_addr:$server_port;
proxy_pass http://localhost:8081;
Now , when I am opening https://mydomain.com/sso I got redirected to https://mydomain:8080/sso , if I remove 8080 everything works great and I can logon into admin console .
I started my clock on port 8081 las below :
kc.bat start --http-port 8081 --http-relative-path /sso --proxy edge --hostname-strict=false.
Please help
