0
I’m currently using Keycloak 20.0.5 version which is working fine with following Dockerfile
and YML
file.
Dockerfile
FROM quay.io/keycloak/keycloak:25.0.0 as builder
WORKDIR /opt/keycloak
COPY --from=builder /opt/keycloak/ /opt/keycloak/
RUN mkdir -p /opt/keycloak/themes/custom_theme
COPY ./custom_theme /opt/keycloak/themes/custom_theme
COPY ./custom_provider.jar /opt/keycloak/providers/custom_provider.jar
ENTRYPOINT ["/opt/keycloak/bin/kc.sh"]
Deployment File
env:
- name: KEYCLOAK_ADMIN
value: admin
- name: KEYCLOAK_ADMIN_PASSWORD
value: admin_password
- name: KC_PROXY
value: edge
- name: KC_DB
value: postgres
- name: KC_DB_URL
value: jdbc:postgresql://sample.rds.amazonaws.com/sample_dev
- name: KC_DB_SCHEMA
value: keycloak
- name: KC_DB_USERNAME
value: db_app_user
- name: KC_DB_PASSWORD
value: db_password
- name: KC_HEALTH_ENABLED
value: "true"
- name: KC_METRICS_ENABLED
value: "true"
- name: KC_HTTP_RELATIVE_PATH
value: /my-keycloak-service/
Public Ingress Configuration
kind: Ingress
metadata:
creationTimestamp: "2024-07-11T07:25:56Z"
generation: 3
namespace: my
resourceVersion: "200565111"
uid: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
spec:
ingressClassName: public-nginx
rules:
- host: xxx.ap-southeast-1.elb.amazonaws.com
http:
paths:
- backend:
service:
port:
number: 8080
path: /my-keycloak-service(/|$)(.*)
pathType: Prefix
status:
loadBalancer:
ingress:
- ip: xx.xxx.xx.xxx
Now I’m trying to migrate into Keycloak 25.x.x version. However after entering admin login credentials, I’m getting following error page. As not sending KC_RESTART
cookie in the http://xxx.ap-southeast-1.elb.amazonaws.com/my-keycloak-service/realms/master/login-actions/authenticate
request.
Even tried adding following ENV
variables to the Dockerfile
ENV KC_HOSTNAME_STRICT=false
ENV KC_HOSTNAME_STRICT_HTTPS=true
ENV KC_HTTP_ENABLED=false
Really appreciate your support on troubleshoot this.
Thank you in advance!
