I am making a change to the KeyCloak password policy, through kcadm.sh update realms/$REALM.
After executing that call from Shell Script, I don’t get any errors, however, when I open the KeyCloak console, all the changed information does not appear.
This information appears until I restart the Docker container that has KeyCloak, which means that the information is being updated.
I want to know if there is any way to restart KeyCloak through some command, or is there a function in kcadm.sh to refresh the information.
I encourage you to do yourself a favor to update Keycloak to the most recent version. Keycloak v9 is 5 years old and more than completely outdated.
Update your environment and test your desired behavior again. Perhaps it’s gone, perhaps it’s still there. If it still persists, try to provide a MRE, so that someone is able to reproduce the behavior and possibly can give you any help.
Please take @dasniko 's advice and upgrade. Yes, the health check endpoint has changed location. That detail, and 1000 others will make it nearly impossible for anyone here to help you with Keycloak 9. If you upgrade, you will have a much better chance of getting community help.
