Hi!
I’m building a fat jar using keycloak-admin-client 13.0.1 (Java).
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-assembly-plugin</artifactId>
<version>3.1.1</version>
<configuration>
<finalName>${finalName}</finalName>
<archive>
<manifest>
<mainClass>org.jboss.pnc.watchdog.keycloak.Main</mainClass>
</manifest>
</archive>
<descriptorRefs>
<descriptorRef>jar-with-dependencies</descriptorRef>
</descriptorRefs>
<appendAssemblyId>false</appendAssemblyId>
</configuration>
<executions>
<execution>
<id>make-assembly</id>
<phase>package</phase>
<goals>
<goal>single</goal>
</goals>
</execution>
</executions>
</plugin>
However, when I run my fat jar, it fails with:
javax.ws.rs.ProcessingException: RESTEASY004655: Unable to invoke request: javax.ws.rs.ProcessingException: RESTEASY003215: could not find writer for content-type application/x-www-form-urlencoded type: javax.ws.rs.core.Form$1
at org.jboss.resteasy.client.jaxrs.engines.ApacheHttpClient4Engine.invoke(ApacheHttpClient4Engine.java:328)
at org.jboss.resteasy.client.jaxrs.internal.ClientInvocation.invoke(ClientInvocation.java:443)
at org.jboss.resteasy.client.jaxrs.internal.proxy.ClientInvoker.invokeSync(ClientInvoker.java:149)
at org.jboss.resteasy.client.jaxrs.internal.proxy.ClientInvoker.invoke(ClientInvoker.java:112)
at org.jboss.resteasy.client.jaxrs.internal.proxy.ClientProxy.invoke(ClientProxy.java:76)
at com.sun.proxy.$Proxy14.grantToken(Unknown Source)
at org.keycloak.admin.client.token.TokenManager.grantToken(TokenManager.java:90)
at org.keycloak.admin.client.token.TokenManager.getAccessToken(TokenManager.java:70)
at org.keycloak.admin.client.token.TokenManager.getAccessTokenString(TokenManager.java:65)
at org.keycloak.admin.client.resource.BearerAuthFilter.filter(BearerAuthFilter.java:52)
at org.jboss.resteasy.client.jaxrs.internal.ClientInvocation.filterRequest(ClientInvocation.java:579)
at org.jboss.resteasy.client.jaxrs.internal.ClientInvocation.invoke(ClientInvocation.java:440)
at com.sun.proxy.$Proxy23.list(Unknown Source)
at org.jboss.pnc.watchdog.keycloak.internal.KeycloakServer.getUsers(KeycloakServer.java:65)
at org.jboss.pnc.watchdog.keycloak.Utils.checkUserRoles(Utils.java:37)
at org.jboss.pnc.watchdog.keycloak.Main.call(Main.java:50)
at org.jboss.pnc.watchdog.keycloak.Main.call(Main.java:14)
at picocli.CommandLine.executeUserObject(CommandLine.java:1953)
at picocli.CommandLine.access$1300(CommandLine.java:145)
at picocli.CommandLine$RunLast.executeUserObjectOfLastSubcommandWithSameParent(CommandLine.java:2352)
at picocli.CommandLine$RunLast.handle(CommandLine.java:2346)
at picocli.CommandLine$RunLast.handle(CommandLine.java:2311)
at picocli.CommandLine$AbstractParseResultHandler.execute(CommandLine.java:2179)
at picocli.CommandLine.execute(CommandLine.java:2078)
at org.jboss.pnc.watchdog.keycloak.Main.main(Main.java:62)
Caused by: javax.ws.rs.ProcessingException: RESTEASY003215: could not find writer for content-type application/x-www-form-urlencoded type: javax.ws.rs.core.Form$1
at org.jboss.resteasy.core.interception.ClientWriterInterceptorContext.throwWriterNotFoundException(ClientWriterInterceptorContext.java:38)
at org.jboss.resteasy.core.interception.AbstractWriterInterceptorContext.getWriter(AbstractWriterInterceptorContext.java:146)
at org.jboss.resteasy.core.interception.AbstractWriterInterceptorContext.proceed(AbstractWriterInterceptorContext.java:121)
at org.jboss.resteasy.client.jaxrs.internal.ClientInvocation.writeRequestBody(ClientInvocation.java:399)
at org.jboss.resteasy.client.jaxrs.engines.ApacheHttpClient4Engine.writeRequestBodyToOutputStream(ApacheHttpClient4Engine.java:678)
at org.jboss.resteasy.client.jaxrs.engines.ApacheHttpClient4Engine.buildEntity(ApacheHttpClient4Engine.java:639)
at org.jboss.resteasy.client.jaxrs.engines.ApacheHttpClient4Engine.loadHttpMethod(ApacheHttpClient4Engine.java:517)
at org.jboss.resteasy.client.jaxrs.engines.ApacheHttpClient4Engine.invoke(ApacheHttpClient4Engine.java:316)
... 27 more
Is there a wrong setting somewhere causing this? It works when running via Intellij.
Sincerely,
Dustin
