I have a SPI implementation which is:
- Custom SPI, directly implemented via SPI interface
- has an external jar which does not exist in JBoss base
- EAR deployment: I tried EAR deployment and deploy my .ear to /standalone/deployments. This solves the external jar problem which is bundled within EAR’s lib folder. But now SPI is not initializing (which I saw when I debug) and also I get an exception when I trigger the SPI:
11:34:02,185 INFO [org.jboss.as] (Controller Boot Thread) WFLYSRV0025: Keycloak 9.0.2 (WildFly Core 10.0.3.Final) started in 12070ms - Started 732 of 1031 services (613 services are lazy, passive or on-demand)
11:34:18,209 ERROR [org.keycloak.services.error.KeycloakErrorHandler] (default task-1) Uncaught server error: java.lang.NullPointerException
at org.keycloak.keycloak-services@9.0.2//org.keycloak.services.DefaultKeycloakSessionFactory.getAllProviderIds(DefaultKeycloakSessionFactory.java:362)
Then I thought maybe keycloak is not able to import extended SPI via standalone/deployment deployment, which is also mentioned here if you develop custom SPI keycloak suggests (or requires?) module deployment.
- Then I tried module deployment; now I can see that my custom SPI is initializing, but now keycloak can not find my external JAR.
13:17:05,682 FATAL [org.keycloak.services] (ServerService Thread Pool -- 65) java.lang.RuntimeException: org.jboss.modules.ModuleNotFoundException: com.orbitz.consul
As a solution, I found somewhere that I can put my dependent jar and all its dependent jar’s to ${KEYCLOAK_HOME}\modules\system\layers\keycloak but I don’t want to install my external JAR and its all dependencies manually to keycloak’s base (maybe automatically somehow?). Any solution?
Script to deploy as a module:
./jboss-cli.bat --command="module add --name=de.easy.one.bouncer.spi.registry --resources=target/registry-spi-1.0.1-SNAPSHOT.jar --dependencies=org.keycloak.keycloak-core,org.keycloak.keycloak-services,org.keycloak.keycloak-server-spi,org.keycloak.keycloak-server-spi-private,javax.api,javax.ws.rs.api,com.fasterxml.jackson.core.jackson-core,com.fasterxml.jackson.core.jackson-databind,com.fasterxml.jackson.core.jackson-annotations,org.jboss.logging,com.orbitz.consul"
And added it to standalone.xml as follows:
<provider>module:de.easy.one.bouncer.spi.registry</provider>
META-INF/services
file name --> file content
org.keycloak.provider.Spi --> de.easy.one.bouncer.spi.registry.spi.RegistryProviderSpi
de.easy.one.bouncer.spi.registry.spi.RegistryProviderFactory --> de.easy.one.bouncer.spi.registry.consul.ConsulRegistryProviderFactory
my pom.xml
<dependencies>
<dependency>
<groupId>org.projectlombok</groupId>
<artifactId>lombok</artifactId>
<scope>provided</scope>
<optional>true</optional>
</dependency>
<dependency>
<artifactId>keycloak-server-spi</artifactId>
</dependency>
<dependency>
<artifactId>keycloak-server-spi-private</artifactId>
</dependency>
<dependency>
<artifactId>keycloak-services</artifactId>
</dependency>
<!-- this is not provided and I want to use as external jar -->
<dependency>
<groupId>com.orbitz.consul</groupId>
<artifactId>consul-client</artifactId>
<version>1.4.2</version>
</dependency>
</dependencies>
