Hi All,
I’m facing an issue while integrate Keycloak with Datadog to monitor the Server.
The logs and traces of Keycloak is not available in Datadog after the integration.
The Datadog jar is downloaded and copied into the deployment folder, also updated the JAVAOPTS
as below
-Ddd.profiling.enabled=true -Ddd.logs.injection=true -Ddd.trace.sample.rate=1 -Ddd.service=keycloak-dev -Ddd.env=Dev -javaagent:/opt/jboss/keycloak/standalone/deployments/dd-java-agent.jar
Could you please help me to solve this issue?
Thanks,
Jithin
