I am having a very strange issue in my keycloak.
When I am accessing the keycloak via admin UI or via keycloak admin API everything is fine. But when I tried to call the token API in postman with wrong client id and client secret, the whole keycloak application stopped working.
{{base_path}}/realms/{{realm_name}}/protocol/openid-connect/token
Tried the same scenario in my local and development setup it works fine as expected. but, my UAT environment configured with kubarnetes and docker have the issue. The other environments giving proper response as,
"error": "invalid_client",
"error_description": "Invalid client or Invalid client credentials"
And the log in the keycloak shows that there is a DB connection issue. But when i checked all the configuration in my development server and UAT server everything is same. Do any one face the similar issue or know why it is happening suddenly after an API call?
2024-05-07 05:42:59,850 ERROR [org.hibernate.engine.jdbc.spi.SqlExceptionHelper] (executor-thread-127) Sorry, acquisition timeout!
2024-05-07 05:42:59,859 ERROR [org.keycloak.services] (executor-thread-127) KC-SERVICES0015: Unexpected error when authenticating client: org.hibernate.exception.GenericJDBCException: Unable to acquire JDBC Connection [Sorry, acquisition timeout!] [n/a]
at org.hibernate.exception.internal.StandardSQLExceptionConverter.convert(StandardSQLExceptionConverter.java:63)
at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:108)
at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:94)
at org.hibernate.resource.jdbc.internal.LogicalConnectionManagedImpl.acquireConnectionIfNeeded(LogicalConnectionManagedImpl.java:116)
at org.hibernate.resource.jdbc.internal.LogicalConnectionManagedImpl.getPhysicalConnection(LogicalConnectionManagedImpl.java:143)
at org.hibernate.engine.jdbc.internal.StatementPreparerImpl.connection(StatementPreparerImpl.java:54)
at org.hibernate.engine.jdbc.internal.StatementPreparerImpl$5.doPrepare(StatementPreparerImpl.java:153)
at org.hibernate.engine.jdbc.internal.StatementPreparerImpl$StatementPreparationTemplate.prepareStatement(StatementPreparerImpl.java:183)
at org.hibernate.engine.jdbc.internal.StatementPreparerImpl.prepareQueryStatement(StatementPreparerImpl.java:155)
at org.hibernate.sql.exec.spi.JdbcSelectExecutor.lambda$list$0(JdbcSelectExecutor.java:85)
at org.hibernate.sql.results.jdbc.internal.DeferredResultSetAccess.executeQuery(DeferredResultSetAccess.java:231)
at org.hibernate.sql.results.jdbc.internal.DeferredResultSetAccess.getResultSet(DeferredResultSetAccess.java:167)
at org.hibernate.sql.results.jdbc.internal.JdbcValuesResultSetImpl.advanceNext(JdbcValuesResultSetImpl.java:218)
at org.hibernate.sql.results.jdbc.internal.JdbcValuesResultSetImpl.processNext(JdbcValuesResultSetImpl.java:98)
at org.hibernate.sql.results.jdbc.internal.AbstractJdbcValues.next(AbstractJdbcValues.java:19)
at org.hibernate.sql.results.internal.RowProcessingStateStandardImpl.next(RowProcessingStateStandardImpl.java:66)
at org.hibernate.sql.results.spi.ListResultsConsumer.consume(ListResultsConsumer.java:202)
at org.hibernate.sql.results.spi.ListResultsConsumer.consume(ListResultsConsumer.java:33)
at org.hibernate.sql.exec.internal.JdbcSelectExecutorStandardImpl.doExecuteQuery(JdbcSelectExecutorStandardImpl.java:209)
at org.hibernate.sql.exec.internal.JdbcSelectExecutorStandardImpl.executeQuery(JdbcSelectExecutorStandardImpl.java:83)
at org.hibernate.sql.exec.spi.JdbcSelectExecutor.list(JdbcSelectExecutor.java:76)
at org.hibernate.sql.exec.spi.JdbcSelectExecutor.list(JdbcSelectExecutor.java:65)
at org.hibernate.query.sqm.internal.ConcreteSqmSelectQueryPlan.lambda$new$2(ConcreteSqmSelectQueryPlan.java:137)
at org.hibernate.query.sqm.internal.ConcreteSqmSelectQueryPlan.withCacheableSqmInterpretation(ConcreteSqmSelectQueryPlan.java:362)
at org.hibernate.query.sqm.internal.ConcreteSqmSelectQueryPlan.performList(ConcreteSqmSelectQueryPlan.java:303)
at org.hibernate.query.sqm.internal.QuerySqmImpl.doList(QuerySqmImpl.java:509)
at org.hibernate.query.spi.AbstractSelectionQuery.list(AbstractSelectionQuery.java:427)
at org.hibernate.query.Query.getResultList(Query.java:120)
at org.keycloak.models.jpa.JpaRealmProvider.getClientByClientId(JpaRealmProvider.java:825)
at org.keycloak.storage.ClientStorageManager.getClientByClientId(ClientStorageManager.java:149)
at org.keycloak.models.cache.infinispan.RealmCacheSession.prepareCachedClientByClientId(RealmCacheSession.java:1291)
at org.keycloak.models.cache.infinispan.RealmCacheSession.lambda$getClientByClientId$6(RealmCacheSession.java:1282)
at org.keycloak.models.cache.infinispan.RealmCacheManager.computeSerialized(RealmCacheManager.java:142)
at org.keycloak.models.cache.infinispan.RealmCacheSession.getClientByClientId(RealmCacheSession.java:1282)
at org.keycloak.authentication.authenticators.client.ClientIdAndSecretAuthenticator.authenticateClient(ClientIdAndSecretAuthenticator.java:105)
at org.keycloak.authentication.ClientAuthenticationFlow.processFlow(ClientAuthenticationFlow.java:72)
at org.keycloak.authentication.AuthenticationProcessor.authenticateClient(AuthenticationProcessor.java:893)
at org.keycloak.protocol.oidc.utils.AuthorizeClientUtil.authorizeClient(AuthorizeClientUtil.java:50)
at org.keycloak.protocol.oidc.endpoints.TokenEndpoint.checkClient(TokenEndpoint.java:168)
at org.keycloak.protocol.oidc.endpoints.TokenEndpoint.processGrantRequest(TokenEndpoint.java:134)
at org.keycloak.protocol.oidc.endpoints.TokenEndpoint$quarkusrestinvoker$processGrantRequest_6408e15340992839b66447750c221d9aaa837bd7.invoke(Unknown Source)
at org.jboss.resteasy.reactive.server.handlers.InvocationHandler.handle(InvocationHandler.java:29)
at io.quarkus.resteasy.reactive.server.runtime.QuarkusResteasyReactiveRequestContext.invokeHandler(QuarkusResteasyReactiveRequestContext.java:141)
at org.jboss.resteasy.reactive.common.core.AbstractResteasyReactiveContext.run(AbstractResteasyReactiveContext.java:147)
at io.quarkus.vertx.core.runtime.VertxCoreRecorder$14.runWith(VertxCoreRecorder.java:582)
at org.jboss.threads.EnhancedQueueExecutor$Task.run(EnhancedQueueExecutor.java:2513)
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1512)
at java.base/java.lang.Thread.run(Thread.java:840)
Caused by: java.sql.SQLException: Sorry, acquisition timeout!
at io.agroal.pool.ConnectionPool.handlerFromSharedCache(ConnectionPool.java:299)
at io.agroal.pool.ConnectionPool.getConnection(ConnectionPool.java:253)
at io.agroal.pool.DataSource.getConnection(DataSource.java:86)
at io.quarkus.hibernate.orm.runtime.customized.QuarkusConnectionProvider.getConnection(QuarkusConnectionProvider.java:23)
at org.hibernate.internal.NonContextualJdbcConnectionAccess.obtainConnection(NonContextualJdbcConnectionAccess.java:46)
at org.hibernate.resource.jdbc.internal.LogicalConnectionManagedImpl.acquireConnectionIfNeeded(LogicalConnectionManagedImpl.java:113)
... 47 more
2024-05-07 05:43:03,253 WARN [org.hibernate.engine.jdbc.spi.SqlExceptionHelper] (executor-thread-132) SQL Error: 0, SQLState: null
2024-05-07 05:43:03,253 ERROR [org.hibernate.engine.jdbc.spi.SqlExceptionHelper] (executor-thread-132) Sorry, acquisition timeout!
2024-05-07 05:43:03,254 WARN [org.keycloak.services] (executor-thread-132) KC-SERVICES0013: Failed authentication: org.hibernate.exception.GenericJDBCException: Unable to acquire JDBC Connection [Sorry, acquisition timeout!] [n/a]
at org.keycloak.models.jpa.JpaUserProvider.getUserByEmail(JpaUserProvider.java:541)
at org.keycloak.storage.UserStorageManager.getUserByEmail(UserStorageManager.java:391)
at org.keycloak.models.cache.infinispan.UserCacheSession.getUserByEmail(UserCacheSession.java:399)
at org.keycloak.userprofile.validator.DuplicateEmailValidator.validate(DuplicateEmailValidator.java:67)
at org.keycloak.userprofile.AttributeValidatorMetadata.validate(AttributeValidatorMetadata.java:80)
at org.keycloak.userprofile.DefaultAttributes.validate(DefaultAttributes.java:178)
at org.keycloak.userprofile.DefaultUserProfile.validate(DefaultUserProfile.java:76)
at org.keycloak.authentication.requiredactions.VerifyUserProfile.evaluateTriggers(VerifyUserProfile.java:63)
at org.keycloak.services.managers.AuthenticationManager.evaluateRequiredAction(AuthenticationManager.java:1353)
at org.keycloak.services.managers.AuthenticationManager.lambda$evaluateRequiredActionTriggers$19(AuthenticationManager.java:1324)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:183)
at java.base/java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:179)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:197)
at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1625)
at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:509)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:499)
at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173)
at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.base/java.util.stream.ReferencePipeline.forEachOrdered(ReferencePipeline.java:601)
at org.keycloak.services.managers.AuthenticationManager.evaluateRequiredActionTriggers(AuthenticationManager.java:1324)
at org.keycloak.services.managers.AuthenticationManager.nextRequiredAction(AuthenticationManager.java:1042)
at org.keycloak.authentication.AuthenticationProcessor.nextRequiredAction(AuthenticationProcessor.java:1138)
at org.keycloak.protocol.AuthorizationEndpointBase.handleBrowserAuthenticationRequest(AuthorizationEndpointBase.java:137)
at org.keycloak.protocol.oidc.endpoints.AuthorizationEndpoint.buildAuthorizationCodeAuthorizationResponse(AuthorizationEndpoint.java:337)
at org.keycloak.protocol.oidc.endpoints.AuthorizationEndpoint.process(AuthorizationEndpoint.java:202)
at org.keycloak.protocol.oidc.endpoints.AuthorizationEndpoint.buildGet(AuthorizationEndpoint.java:113)
at org.keycloak.protocol.oidc.endpoints.AuthorizationEndpoint$quarkusrestinvoker$buildGet_4b690b27439f19dd29733dc5fd4004f24de0adb6.invoke(Unknown Source)
at org.jboss.threads.EnhancedQueueExecutor$ThreadBody.run(EnhancedQueueExecutor.java:1538)
... 63 more
I have checked the DB connection from the container multiple time after seeing this error, connection is fine. If connection is not fine, it shouldn’t work before the API call as well, right?.
