GitHub Issue… Keycloak High Availability with PostgreSQL on Kubernetes · Issue #26550 · keycloak/keycloak · GitHub
Describe the bug
Keycloak
(and Postgres
) will deploy without issue and become ready, but when accessing the user interface, it renders incorrectly, and depending on which pod of keycloak
you hit, it will render differently… I can’t determine or figure out if the issue is within infinispan
or postgres
or something else…
I have tried almost every combination of deployment options and configurations (Embedded Database, Postgres Database, DNG PING, KUBE PING, JDBC…) over the last 3 days and nothing will work!! In the reproduction section, I have the deployment manifests. In the actual behavior section, I have the logs of each related pod.
If I only deploy one instance keycloak
, with or without an external database, there are no issues. Additionally, I realize not everything in the manifests are required, but I have been doing a lot of trial and error.
Version
Keycloak - Version 23.0.4 (Quay)
Expected behavior
Ability to deploy three instance of Keycloak
and have functionality!
Actual behavior
Screenshots
Keycloak Pod Logs
keycloak-785d6cd755-79vw9_keycloak.log
keycloak-785d6cd755-bjtlr_keycloak.log
keycloak-785d6cd755-vwxhh_keycloak.log
Postgres Pod Logs
postgresql-0_postgresql.log
postgresql-1_postgresql.log
postgresql-2_postgresql.log
How to Reproduce?
Keycloak Manifests
apiVersion: apps/v1
kind: Deployment
metadata:
namespace: keycloak-system
labels:
app: keycloak
spec:
replicas: 3
selector:
matchLabels:
app: keycloak
template:
metadata:
labels:
app: keycloak
spec:
serviceAccount: keycloak-kubeping
serviceAccountName: keycloak-kubeping
containers:
- name: keycloak
image: quay.io/keycloak/keycloak
args: ["start"]
env:
- name: KC_DB
value: "postgres"
- name: KC_DB_URL
value: "jdbc:postgresql://postgresql-service:5432/keycloak"
- name: POSTGRES_DB
valueFrom:
secretKeyRef:
key: POSTGRES_DB
- name: KC_DB_USERNAME
valueFrom:
secretKeyRef:
key: POSTGRES_USER
- name: KC_DB_PASSWORD
valueFrom:
secretKeyRef:
key: POSTGRES_PASSWORD
- name: KEYCLOAK_ADMIN
valueFrom:
secretKeyRef:
key: KEYCLOAK_ADMIN
- name: KEYCLOAK_ADMIN_PASSWORD
valueFrom:
secretKeyRef:
key: KEYCLOAK_ADMIN_PASSWORD
- name: KC_HOSTNAME
value: "<redacted>"
- name: KC_PRODUCTION
value: "true"
- name: KC_CACHE
value: "ispn"
- name: KC_CACHE_STACK
value: "kubernetes"
- name: jgroups.dns.query
value: "keycloak-headless-service.keycloak-system.svc.cluster.local"
- name: CACHE_OWNERS_COUNT
value: "3"
- name: CACHE_OWNERS_AUTH_SESSIONS_COUNT
value: "3"
value: "true"
- name: KC_PROXY
value: "edge"
- name: KC_HEALTH_ENABLED
value: "true"
- name: KC_METRICS_ENABLED
value: "true"
- name: KC_HOSTNAME_STRICT
value: "false"
- name: KC_HOSTNAME_STRICT_BACKCHANNEL
value: "false"
- name: KC_HOSTNAME_STRICT_HTTPS
value: "false"
- name: KC_HTTP_ENABLED
value: "true"
ports:
- name: http
containerPort: 8080
protocol: TCP
- name: https
containerPort: 8443
protocol: TCP
- name: infinispan
containerPort: 7800
protocol: UDP
apiVersion: v1
kind: Service
metadata:
labels:
app: keycloak
spec:
ports:
- name: http
port: 8080
targetPort: 8080
protocol: TCP
- name: infinispan
port: 7800
targetPort: 7800
protocol: UDP
selector:
app: keycloak
type: ClusterIP
apiVersion: v1
kind: Service
metadata:
labels:
app: keycloak
spec:
selector:
app: keycloak
clusterIP: None
publishNotReadyAddresses: true
kind: Ingress
metadata:
labels:
app: keycloak
spec:
rules:
- host: <redacted>
http:
paths:
- backend:
service:
port:
number: 8080
path: /
pathType: ImplementationSpecific
tls:
- hosts:
- <redacted>
secretName: tls-certs
apiVersion: v1
kind: Secret
metadata:
type: Opaque
stringData:
KEYCLOAK_ADMIN: admin
KEYCLOAK_ADMIN_PASSWORD: <redacted
apiVersion: v1
kind: ServiceAccount
metadata:
apiVersion: rbac.authorization.k8s.io/v1
kind: Role
metadata:
rules:
- apiGroups: ["*"]
resources: ["pods"]
verbs: ["get", "list", "watch"]
kind: RoleBinding
metadata:
annotations:
roleRef:
apiGroup: rbac.authorization.k8s.io
kind: Role
subjects:
- kind: ServiceAccount
apiVersion: ui.cattle.io/v1
kind: NavLink
metadata:
spec:
label: Keycloak
target: _blank
description: Keycloak Authenication
group: Keycloak Authenication
label: Keycloak
sideLabel: KEYCLOAK
toURL: <redacted>
Postgres Manifests
apiVersion: apps/v1
kind: StatefulSet
metadata:
spec:
serviceName: postgresql-service
replicas: 3
selector:
matchLabels:
app: postgresql
template:
metadata:
labels:
app: postgresql
spec:
containers:
- name: postgresql
image: postgres:latest
env:
- name: POSTGRES_DB
valueFrom:
secretKeyRef:
key: POSTGRES_DB
- name: POSTGRES_USER
valueFrom:
secretKeyRef:
key: POSTGRES_USER
- name: POSTGRES_PASSWORD
valueFrom:
secretKeyRef:
- name: PGDATA
value: /var/lib/postgresql/data/pgdata
ports:
- containerPort: 5432
volumeMounts:
- name: postgresql-data
mountPath: /var/lib/postgresql/data
volumeClaimTemplates:
- metadata:
spec:
accessModes: ["ReadWriteOnce"]
resources:
requests:
storage: 10Gi
apiVersion: v1
kind: Service
metadata:
spec:
selector:
app: postgresql
ports:
- port: 5432
targetPort: 5432
type: ClusterIP
apiVersion: v1
kind: Secret
metadata:
type: Opaque
stringData:
POSTGRES_DB: keycloak
POSTGRES_USER: postgres
POSTGRES_PASSWORD: <redacted>
Anything else?
No response
