Hi!
I installed two EC2 instances, each running Keycloak in standalone-ha mode with one RDS database. I put AWS Application Load Balancer in front of the instants.
Scheme:
Configured Discourse test forum with OpenID plugin for Keycloak authentication. And from that moment on the weirdness began…
I go to the main page of the test forum:
I click Login and go to the Keycloak instance that AWS ALB selects:
I log in there and return me to the main page of the forum with the following error:
After several cycles “go to the main page of the forum → refresh the page → click Login” a miracle happens - suddenly the session is picked up! And I enter the forum:
AWS ALB settings:
AWS ALB Listeners:
AWS ALB Target Group:
I’m sure this is some kind of problem in the ALB-Keycloak bundle.
Because when I turn off one of the two targets in the ALB Target Group, any - the problems go away, authorization occurs immediately, without errors.
Can someone tell me what I misconfigured? Thanks a lot in advance!
