As per Keycloak update, Keycloak 22 is upgraded to JakartaEE. But still keycloak-tomcat-adapter-22-0.0.jar refers javax.servlet.http.HttpServletResponse.Please suggest which version keycloak is completely upgraded to JakarataEE.
I have same issue. it seems that it is not mentioned any where.
The adapters are deprecated and won’t be updated anymore.
Use some other publicly available OIDC adapters for your desired environment!
Thank you! do you have any recommendation? I am searching for several days. except the one maintained by KC, I don’t find any good OIDC adapter. I start thinking to migrate keycloak tomcat adapter by myself.
I don’t have much experience with Tomcat. But possibly https://www.pac4j.org/ is an option, there’s pac4j: security for Java for OIDC.
unfortunately I am also having same problem…are you able to figure it out?
