We have a setup where:
Setup working up to 16.x.x
keycloak: https://kc-int.local/auth ==> https://localhost:8443/auth (nginx reverse proxy on KC server)
App1: https://app1.com/auth ==> https://kc-int.local/auth (realm = realm-app1)
App1: https://app1.com/whatever ==> https://appserver1.local/whatever (realm = realm-app1)
App1-int: https://app1.local/auth ==> https://kc-int.local/auth (realm = realm-app1)
App1-int: https://app1.local/whatever ==> https://appserver1.local/whatever (realm = realm-app1)
App2: https://app2.com/auth ==> https://kc-int.local/auth (realm = realm-app2)
App2: https://app2.com/whatever ==> https://appserver2.local/whatever (realm = realm-app2)
Up to Keycloak 16.1.0 (11.0.2, 15.x.x etc.) all redirects/followup pages happened to the app1.com / app1.local / app2.com respective hostnames
Since Keycloak 17.0.0 the login page is shown, ANY follow up page is done using: kc-int.local/auth/… with the error that Cookies are invalid.
Understandable as the cookies are registerrd to app1.com, app1.local, app2.com respectively.
Each of the app’s does have it’s own realm inside Keycloak
Effectively keycloak could be used transparently for several environments where needed. Adding a realm where needed.
Keycloak has nginx as reverse proxy on the own host. (to filter some unwanted URL’s if they happen to be sent somehow).
All other services are behind a reverse proxy that dispatches to either the app server / keycloak depending on URL provided.
Unlike the unreachable admin pages issues described elsewhere, this is the opposite, the admin pages ARE reachable the various frontends are not, they al lredirect to the internal hostname for the keycloak server.
Note: I am aware of
which adjusts the frontend-url in settings…, this would allow for a realm to be used once with a specific URL…, it does not work for a realm used with multiple different hostnames in the URL’s
