Hi All,
I have this docker compose file that starts Keycloak version 22 in development mode.
The idea is to have a postgresql db retaining the user data after “docker compose down”
the code below works with keycloak wildfly distributions, but in quarkus ones it doesn’t seem to retain data.
version: '3.4'
services:
postgres:
image: postgres
container_name: postgres-kc
volumes:
- ./postgres_data:/var/lib/postgresql/data 777
environment:
POSTGRES_DB: keycloak
POSTGRES_USER: keycloak
POSTGRES_PASSWORD: keycloak
networks:
- kc-lite
keycloak:
image: quay.io/keycloak/keycloak:22.0.3
container_name: keycloak
restart: always
healthcheck:
test: ["CMD", "curl", "http://localhost:8081/auth"]
interval: 30s
start_period: 2m
retries: 10
environment:
DB_VENDOR: POSTGRES
DB_ADDR: postgres
DB_DATABASE: keycloak
DB_USER: keycloak
DB_SCHEMA: public
DB_PASSWORD: keycloak
# KEYCLOAK_USER: admin #for wildfly distributions
# KEYCLOAK_PASSWORD: admin #for wildfly distributions
KEYCLOAK_ADMIN: admin #for quarkus
KEYCLOAK_ADMIN_PASSWORD: admin #for quarkus
# Uncomment the line below if you want to specify JDBC parameters. The parameter below is just an example, and it shouldn't be used in production without knowledge. It is highly recommended that you read the PostgreSQL JDBC driver documentation in order to use it.
#JDBC_PARAMS: "ssl=true"
ports:
- 8081:8080
depends_on:
- postgres
networks:
- kc-lite
command: #for quarkus
- start-dev
networks:
kc-lite:
driver: bridge
