Keycloak removes port from redirect_uri
Weird problem: the url that is secured with Keycloak is testserver:8081/application. The redirect happens, but the keycloak-page gives an error:
invalid parameter: redirect_uri.
When I look at the redirect_uri in the url I notice something strange; the port is omitted, it just shows
“redirect_uri=https%3A%2F%2Ftestserver%2Fapplication”
Why did Keylcoak filter away the port??
If I manually adjust the url (I add the port - 8081) it works just fine…I’m confused.
Can you show us an example of what library you’re using (keycloak-js?) and how you’re using it? Some more context would be helpful in debugging.
I’m using Keycloak to secure a java-app (Vaadin), so i’m using a java-adapter. Securing my application by adding my secured path in the web.xml.
When I run my app locally on localhost, it all works perfect. I get redirected to our test-keycloak-server and I can login and everything. But once deployed on our test-server (tomcat) I get this strange behavior.
Maybe one thing to note: our testserver doesn’t use https, could this explain anything?
Also, the ‘Valid Redirect URIs’ you need to set in Keycloak are set correctly.
The first problem I had was that instead of removing the port Keycloak removed it and added ‘0’, giving me this url:
testserver:0/application
I solved this by adding ‘confidential-port: 443’ to my keycloak.json, and so now it completely strips away the port-number…
