I downloaded the latest jgroups-kubernetes jar
file from this website Maven Central Repository Search and placed it in in lib/lib/main
directory of Keycloak 17.0.0
This is my new cache-ispn-kube-ping.xml
file
<infinispan
xsi:schemaLocation="urn:infinispan:config:11.0 http://www.infinispan.org/schemas/infinispan-config-11.0.xsd"
xmlns="urn:infinispan:config:11.0">
<!-- custom stack goes into the jgroups element -->
<jgroups>
<stack name="kube-ping-tcp" extends="tcp">
<org.jgroups.protocols.kubernetes.KUBE_PING
namespace="default"
stack.combine="REPLACE"
stack.position="MPING" />
</stack>
</jgroups>
<!-- custom stack must be referenced by name in the stack attribute of the transport element -->
<transport lock-timeout="60000" stack="kube-ping-tcp"/>
<local-cache name="realms">
<encoding>
</encoding>
<memory max-count="10000"/>
</local-cache>
<local-cache name="users">
<encoding>
</encoding>
</local-cache>
<expiration lifespan="-1"/>
</distributed-cache>
<encoding>
</encoding>
</local-cache>
</replicated-cache>
<local-cache name="keys">
<encoding>
</encoding>
<memory max-count="1000"/>
</local-cache>
<encoding>
</encoding>
<memory max-count="-1"/>
</cache-container>
</infinispan>
When I execute the command
kc.sh --verbose start-dev --cache=ispn --cache-config-file=cache-ispn-kube-ping.xml
I get this following error log
2022-03-24 18:57:36,862 INFO [io.quarkus.deployment.QuarkusAugmentor] (main) Quarkus augmentation completed in 10416ms
2022-03-24 18:57:41,268 INFO [org.keycloak.quarkus.runtime.hostname.DefaultHostnameProvider] (main) Hostname settings: FrontEnd: <request>, Strict HTTPS: false, Path: <request>, Strict BackChannel: false, Admin: <request>
2022-03-24 18:57:42,327 WARN [org.infinispan.CONFIG] (keycloak-cache-init) ISPN000569: Unable to persist Infinispan internal caches as no global state enabled
2022-03-24 18:57:42,401 WARN [org.infinispan.PERSISTENCE] (keycloak-cache-init) ISPN000554: jboss-marshalling is deprecated and planned for removal
2022-03-24 18:57:42,492 INFO [org.infinispan.CONTAINER] (keycloak-cache-init) ISPN000556: Starting user marshaller 'org.infinispan.jboss.marshalling.core.JBossUserMarshaller'
2022-03-24 18:57:42,888 INFO [org.infinispan.CONTAINER] (keycloak-cache-init) ISPN000128: Infinispan version: Infinispan 'Triskaidekaphobia' 13.0.5.Final
2022-03-24 18:57:43,124 INFO [org.infinispan.CLUSTER] (keycloak-cache-init) ISPN000078: Starting JGroups channel `ISPN` with stack `kube-ping-tcp`
2022-03-24 18:57:43,451 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) ERROR: Failed to start server in (development) mode
2022-03-24 18:57:43,452 ERROR [org.keycloak.quarkus.runtime.cli.ExecutionExceptionHandler] (main) Error details:: java.lang.RuntimeException: Failed to start caches
at org.keycloak.quarkus.runtime.storage.infinispan.CacheManagerFactory.getOrCreate(CacheManagerFactory.java:53)
at org.keycloak.quarkus.runtime.storage.infinispan.CacheManagerFactory_6ec50d2dc78e759865b1f14e1c157f33d9676e70_Synthetic_ClientProxy.getOrCreate(Unknown Source)
at org.keycloak.quarkus.runtime.storage.infinispan.QuarkusCacheManagerProvider.getCacheManager(QuarkusCacheManagerProvider.java:32)
at org.keycloak.connections.infinispan.DefaultInfinispanConnectionProviderFactory.lazyInit(DefaultInfinispanConnectionProviderFactory.java:139)
at org.keycloak.connections.infinispan.DefaultInfinispanConnectionProviderFactory.create(DefaultInfinispanConnectionProviderFactory.java:81)
at org.keycloak.connections.infinispan.DefaultInfinispanConnectionProviderFactory.create(DefaultInfinispanConnectionProviderFactory.java:65)
at org.keycloak.services.DefaultKeycloakSession.getProvider(DefaultKeycloakSession.java:316)
at org.keycloak.models.sessions.infinispan.InfinispanActionTokenStoreProviderFactory.initActionTokenCache(InfinispanActionTokenStoreProviderFactory.java:52)
at org.keycloak.models.sessions.infinispan.InfinispanActionTokenStoreProviderFactory.postInit(InfinispanActionTokenStoreProviderFactory.java:67)
at org.keycloak.quarkus.runtime.integration.QuarkusKeycloakSessionFactory.init(QuarkusKeycloakSessionFactory.java:96)
at org.keycloak.quarkus.runtime.integration.jaxrs.QuarkusKeycloakApplication.initializeKeycloakSessionFactory(QuarkusKeycloakApplication.java:75)
at org.keycloak.quarkus.runtime.integration.jaxrs.QuarkusKeycloakApplication.startup(QuarkusKeycloakApplication.java:56)
at org.keycloak.quarkus.runtime.integration.QuarkusLifecycleObserver.onStartupEvent(QuarkusLifecycleObserver.java:37)
at org.keycloak.quarkus.runtime.integration.QuarkusLifecycleObserver_Observer_onStartupEvent_8292a286c9778cb4a07bc3314fcbfb61e7fe81a0.notify(Unknown Source)
at io.quarkus.arc.impl.EventImpl$Notifier.notifyObservers(EventImpl.java:320)
at io.quarkus.arc.impl.EventImpl$Notifier.notify(EventImpl.java:302)
at io.quarkus.arc.impl.EventImpl.fire(EventImpl.java:73)
at io.quarkus.arc.runtime.ArcRecorder.fireLifecycleEvent(ArcRecorder.java:128)
at io.quarkus.arc.runtime.ArcRecorder.handleLifecycleEvents(ArcRecorder.java:97)
at io.quarkus.deployment.steps.LifecycleEventsBuildStep$startupEvent1144526294.deploy_0(Unknown Source)
at io.quarkus.deployment.steps.LifecycleEventsBuildStep$startupEvent1144526294.deploy(Unknown Source)
at io.quarkus.runner.ApplicationImpl.doStart(Unknown Source)
at io.quarkus.runtime.Application.start(Application.java:101)
at io.quarkus.runtime.ApplicationLifecycleManager.run(ApplicationLifecycleManager.java:104)
at io.quarkus.runtime.Quarkus.run(Quarkus.java:67)
at org.keycloak.quarkus.runtime.KeycloakMain.start(KeycloakMain.java:84)
at org.keycloak.quarkus.runtime.cli.command.AbstractStartCommand.run(AbstractStartCommand.java:34)
at picocli.CommandLine.executeUserObject(CommandLine.java:1939)
at picocli.CommandLine.access$1300(CommandLine.java:145)
at picocli.CommandLine$RunLast.executeUserObjectOfLastSubcommandWithSameParent(CommandLine.java:2358)
at picocli.CommandLine$RunLast.handle(CommandLine.java:2352)
at picocli.CommandLine$RunLast.handle(CommandLine.java:2314)
at picocli.CommandLine$AbstractParseResultHandler.execute(CommandLine.java:2179)
at picocli.CommandLine$RunLast.execute(CommandLine.java:2316)
at picocli.CommandLine.execute(CommandLine.java:2078)
at org.keycloak.quarkus.runtime.cli.Picocli.parseAndRun(Picocli.java:84)
at org.keycloak.quarkus.runtime.KeycloakMain.main(KeycloakMain.java:79)
at io.quarkus.bootstrap.runner.QuarkusEntryPoint.doRun(QuarkusEntryPoint.java:60)
at io.quarkus.bootstrap.runner.QuarkusEntryPoint.main(QuarkusEntryPoint.java:31)
Caused by: java.util.concurrent.ExecutionException: org.infinispan.manager.EmbeddedCacheManagerStartupException: org.infinispan.commons.CacheConfigurationException: ISPN000541: Error while trying to create a channel using the specified configuration '[TCP(send_buf_size=640k, thread_pool.max_threads=200, sock_conn_timeout=300, bundler_type=transfer-queue, thread_pool.keep_alive_time=60000, bind_addr=SITE_LOCAL, thread_dumps_threshold=10000, bind_port=7800, enable_diagnostics=false, thread_naming_pattern=pl, thread_pool.min_threads=0), MPING(ip_ttl=2, mcast_port=46655, mcast_addr=228.6.7.8, num_discovery_runs=3), MERGE3(max_interval=30000, min_interval=10000), FD_SOCK(), FD_ALL(interval=2000, timeout_check_interval=1000, timeout=10000), VERIFY_SUSPECT(timeout=1000), pbcast.NAKACK2(xmit_table_num_rows=50, use_mcast_xmit=false, xmit_table_msgs_per_row=1024, xmit_table_max_compaction_time=30000, xmit_interval=100, resend_last_seqno=true), UNICAST3(xmit_interval=100, xmit_table_num_rows=50, xmit_table_msgs_per_row=1024, xmit_table_max_compaction_time=30000), pbcast.STABLE(desired_avg_gossip=5000, max_bytes=1M), pbcast.GMS(join_timeout=2000, print_local_addr=false), UFC(min_threshold=0.40, max_credits=4m), MFC(min_threshold=0.40, max_credits=4m), FRAG3(), org.jgroups.protocols.kubernetes.KUBE_PING(namespace=default)]'
at java.base/java.util.concurrent.FutureTask.report(FutureTask.java:122)
at java.base/java.util.concurrent.FutureTask.get(FutureTask.java:205)
at org.keycloak.quarkus.runtime.storage.infinispan.CacheManagerFactory.getOrCreate(CacheManagerFactory.java:51)
... 42 more
Caused by: org.infinispan.manager.EmbeddedCacheManagerStartupException: org.infinispan.commons.CacheConfigurationException: ISPN000541: Error while trying to create a channel using the specified configuration '[TCP(send_buf_size=640k, thread_pool.max_threads=200, sock_conn_timeout=300, bundler_type=transfer-queue, thread_pool.keep_alive_time=60000, bind_addr=SITE_LOCAL, thread_dumps_threshold=10000, bind_port=7800, enable_diagnostics=false, thread_naming_pattern=pl, thread_pool.min_threads=0), MPING(ip_ttl=2, mcast_port=46655, mcast_addr=228.6.7.8, num_discovery_runs=3), MERGE3(max_interval=30000, min_interval=10000), FD_SOCK(), FD_ALL(interval=2000, timeout_check_interval=1000, timeout=10000), VERIFY_SUSPECT(timeout=1000), pbcast.NAKACK2(xmit_table_num_rows=50, use_mcast_xmit=false, xmit_table_msgs_per_row=1024, xmit_table_max_compaction_time=30000, xmit_interval=100, resend_last_seqno=true), UNICAST3(xmit_interval=100, xmit_table_num_rows=50, xmit_table_msgs_per_row=1024, xmit_table_max_compaction_time=30000), pbcast.STABLE(desired_avg_gossip=5000, max_bytes=1M), pbcast.GMS(join_timeout=2000, print_local_addr=false), UFC(min_threshold=0.40, max_credits=4m), MFC(min_threshold=0.40, max_credits=4m), FRAG3(), org.jgroups.protocols.kubernetes.KUBE_PING(namespace=default)]'
at org.infinispan.manager.DefaultCacheManager.internalStart(DefaultCacheManager.java:756)
at org.infinispan.manager.DefaultCacheManager.start(DefaultCacheManager.java:720)
at org.infinispan.manager.DefaultCacheManager.<init>(DefaultCacheManager.java:401)
at org.keycloak.quarkus.runtime.storage.infinispan.CacheManagerFactory.startCacheManager(CacheManagerFactory.java:72)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
Caused by: org.infinispan.commons.CacheConfigurationException: ISPN000541: Error while trying to create a channel using the specified configuration '[TCP(send_buf_size=640k, thread_pool.max_threads=200, sock_conn_timeout=300, bundler_type=transfer-queue, thread_pool.keep_alive_time=60000, bind_addr=SITE_LOCAL, thread_dumps_threshold=10000, bind_port=7800, enable_diagnostics=false, thread_naming_pattern=pl, thread_pool.min_threads=0), MPING(ip_ttl=2, mcast_port=46655, mcast_addr=228.6.7.8, num_discovery_runs=3), MERGE3(max_interval=30000, min_interval=10000), FD_SOCK(), FD_ALL(interval=2000, timeout_check_interval=1000, timeout=10000), VERIFY_SUSPECT(timeout=1000), pbcast.NAKACK2(xmit_table_num_rows=50, use_mcast_xmit=false, xmit_table_msgs_per_row=1024, xmit_table_max_compaction_time=30000, xmit_interval=100, resend_last_seqno=true), UNICAST3(xmit_interval=100, xmit_table_num_rows=50, xmit_table_msgs_per_row=1024, xmit_table_max_compaction_time=30000), pbcast.STABLE(desired_avg_gossip=5000, max_bytes=1M), pbcast.GMS(join_timeout=2000, print_local_addr=false), UFC(min_threshold=0.40, max_credits=4m), MFC(min_threshold=0.40, max_credits=4m), FRAG3(), org.jgroups.protocols.kubernetes.KUBE_PING(namespace=default)]'
at org.infinispan.remoting.transport.jgroups.JGroupsTransport.channelFromConfigurator(JGroupsTransport.java:696)
at org.infinispan.remoting.transport.jgroups.JGroupsTransport.buildChannel(JGroupsTransport.java:666)
at org.infinispan.remoting.transport.jgroups.JGroupsTransport.initChannel(JGroupsTransport.java:478)
at org.infinispan.remoting.transport.jgroups.JGroupsTransport.start(JGroupsTransport.java:463)
at org.infinispan.remoting.transport.jgroups.CorePackageImpl$1.start(CorePackageImpl.java:41)
at org.infinispan.remoting.transport.jgroups.CorePackageImpl$1.start(CorePackageImpl.java:27)
at org.infinispan.factories.impl.BasicComponentRegistryImpl.invokeStart(BasicComponentRegistryImpl.java:617)
at org.infinispan.factories.impl.BasicComponentRegistryImpl.doStartWrapper(BasicComponentRegistryImpl.java:608)
at org.infinispan.factories.impl.BasicComponentRegistryImpl.startWrapper(BasicComponentRegistryImpl.java:577)
at org.infinispan.factories.impl.BasicComponentRegistryImpl.access$700(BasicComponentRegistryImpl.java:30)
at org.infinispan.factories.impl.BasicComponentRegistryImpl$ComponentWrapper.running(BasicComponentRegistryImpl.java:808)
at org.infinispan.metrics.impl.MetricsCollector.start(MetricsCollector.java:70)
at org.infinispan.metrics.impl.CorePackageImpl$1.start(CorePackageImpl.java:41)
at org.infinispan.metrics.impl.CorePackageImpl$1.start(CorePackageImpl.java:34)
at org.infinispan.factories.impl.BasicComponentRegistryImpl.startDependencies(BasicComponentRegistryImpl.java:635)
at org.infinispan.factories.impl.BasicComponentRegistryImpl.doStartWrapper(BasicComponentRegistryImpl.java:599)
at org.infinispan.factories.AbstractComponentRegistry.internalStart(AbstractComponentRegistry.java:354)
at org.infinispan.factories.AbstractComponentRegistry.start(AbstractComponentRegistry.java:250)
at org.infinispan.manager.DefaultCacheManager.internalStart(DefaultCacheManager.java:752)
... 7 more
Caused by: java.lang.ClassNotFoundException: org.jgroups.protocols.kubernetes.KUBE_PING
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:581)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:178)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
at io.quarkus.bootstrap.runner.RunnerClassLoader.loadClass(RunnerClassLoader.java:107)
at io.quarkus.bootstrap.runner.RunnerClassLoader.loadClass(RunnerClassLoader.java:57)
at java.base/java.lang.Class.forName0(Native Method)
at java.base/java.lang.Class.forName(Class.java:398)
at org.infinispan.commons.util.Util.loadClassStrict(Util.java:171)
at org.infinispan.commons.util.Util.getInstanceStrict(Util.java:320)
at org.infinispan.remoting.transport.jgroups.EmbeddedJGroupsChannelConfigurator.createChannel(EmbeddedJGroupsChannelConfigurator.java:83)
at org.infinispan.remoting.transport.jgroups.JGroupsTransport.channelFromConfigurator(JGroupsTransport.java:694)
... 33 more
