Is it possible to configure each clients in a single realm to sign-in everytime? Here are the different flows I need to support somehow.
- Login to a dashboard - client from same realm (Public client and Auth Code Flow)
- Select an application which is also a client from the same realm
2.1 User must sign-in every time after selecting an app
2.2 Ability to destroy the previous session of selected application but not the dashboard
One thing i’m confused with #2 is that when I sign-in to application-one from the dashboard and I click application 2, the session of application-two and application-one is combined not like the dashboard which is a separate keycloak session.
Options I tried
- Client specific Authentication flow overrides using a copy of browser flow BUT with disabled cookie. My issue here is that if I reload, I need to sign-in again even if there is still a session from Keycloak.
- Custom Event Listener onLogin - I call AuthenticationManager backchannelLogout to remove the previous session that don’t have the dashboard session.
Any suggestions would help. Thank you.
