Migrating from IdentityServer4 to Keycloack
Hi, we are using at the moment, IdentityServer4 and we want to migrate to Keycloak.
The main problem that we encounter is password hashing, IdentityServer4 uses Argon2id and Keycloak uses Pbkdf2 as far as I can see.
How can we migrate without asking the user to register the password.
Thank you!
Did you figure out how to successfully migrate from IdentityServer4 to Keycloak?
Argon2 is now the default password hashing algorithm used by Keycloak in a non-FIPS environment.
